wezzo18 Posted September 29, 2017 Posted September 29, 2017 I need help slicing this at a 45 Degree. Quote
BIGAL Posted September 30, 2017 Posted September 30, 2017 I take it you want to SUBTRACT a WEDGE from the object. Is that correct ? Quote
JD Mather Posted October 2, 2017 Posted October 2, 2017 Sketch 45° line. Split and select the Split Part (or Trim) option and select the line from the sketch. Attach your file here if you can't figure it out. Quote
