mstg007 Posted September 29, 2017 Posted September 29, 2017 How hard is it to create a routine that when the user selects objects during the fillet command that it explodes them first? I can not fillet with radius with straight polylines and exploded arcs. If both are exploded. I can fillet them with a radius. I hope this is somewhat doing about... This will save a lot of extra exploding! lol. Thank you again. Quote
Grrr Posted September 29, 2017 Posted September 29, 2017 "during" the ***** command is a problem, you could first pick two objects and then "batch fillet" them (I hope I explained correctly). I attempted to write some solution, but failed - atleast ended up with some "handy" subfunction: ; _$ (_PickSegment "\nPick something: ") -> (<Entity name: 8998e85ce0> (297752.0 -203065.0 0.0)) ; Returns the 'entsel' result from the picked Line/Arc or if Polyline, list of: (<PickedSegment [As Line Or Arc] Ename> <PickedPoint>) (defun _PickSegment ( msg / pick e typ newpick Exploded o r ) (setvar 'errno 0) (while (/= 52 (getvar 'errno)) (setq pick (entsel msg)) (cond ( (= 7 (getvar 'errno)) (setvar 'errno 0) ) ( (not (setq e (car pick))) ) ( (wcmatch (setq typ (cdr (assoc 0 (entget e)))) "*POLYLINE") (setq newpick ; We've just exploded the POLYLINE, now find the associated entity segment from the 'Exploded' list, by temporarily erasing any overlapping entities ( (lambda ( p L / s tmp r dL ) (while (and (not s) (setq tmp (car (nentselp p)))) (or (and (setq r (cdr (assoc (cdr (assoc 5 (entget tmp))) L))) (setq s T)) (and (setq dL (cons tmp dL)) (entdel tmp)) ) ) (if dL (mapcar 'entdel dL)) (if r (list r p)) ) (cadr pick) (setq Exploded (mapcar '(lambda (x) (cons (vlax-get x 'Handle) (vlax-vla-object->ename x))) (vlax-invoke (setq o (vlax-ename->vla-object e)) 'Explode))) ) ) (mapcar 'entdel (mapcar 'cdr Exploded)) ; Erase every generated object from the 'Explode' method (entdel (car newpick)) ; UnErase the segment entity (setq r newpick) (setvar 'errno 52) ) ( (member typ '("LINE" "ARC")) (setq r pick) (setvar 'errno 52) ) ) ) r ); defun _PickSegment Might help the guys who attempt something here.. BTW I think that there are solution(s) for your problem (perhaps search more carefully?) Quote
BIGAL Posted September 30, 2017 Posted September 30, 2017 mstg007 you need to post a image or dwg showing what your trying to do you may not need a explode. Quote
mstg007 Posted October 2, 2017 Author Posted October 2, 2017 Hopefully this will help. The Red line is a "line". If I explode everything. It works. That's why I was wondering if there was a possibility of a routine that would work with these situations. Quote
Roy_043 Posted October 3, 2017 Posted October 3, 2017 This is obviously related to this: https://www.theswamp.org/index.php?topic=51357.0 Quote
mstg007 Posted October 3, 2017 Author Posted October 3, 2017 You are so correct. Thank you for the cross post. Quote
