Hi all.
i have been experiencing this strange anomaly.
i have created a 3D model of a buffer tank using AutoCad 2017.
after returning to the drawing after a few weeks, i am unable to update my already created isometric views. The Following message comes up "
Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD."
which is strange because in our company we do not have a newer version of AutoCad.
i am also not able to create new views. i get the same message when trying to create a new view/s.
previous to this message i had another issue which arose.
when creating a new base view (parent view) i would not get the complete model. i would only get a angle iron or a plate.
i managed to overcome this by scaling the model up by 1.0001.
This was the only way i could get around this issue.
however i tried this with this current model and this did not work. i then copied the model over to a new drawing, i tried creating a new base view and got the message again.
i have contacted our service provider and they seem very stumped and are not really familiar with the drawing method of using base views or projected views.
i am really hoping that some one here can assist me. i have been forced to redo this drawing and i have been halted by getting this message again.
i can still work on the model but non of my views update and i am not able to create new views. Even though sometimes i create a new projection from an existing view i get the message that i has been successfully created , there is nothing to show.
i have attached a link to my Google Drive to access the said file.
https://drive.google.com/open?id=0Bx25qgO1bh1wZ0hTRjFJWWxDdFk
Your basic problem (i.e. - views that won't update) seems vaguely familiar. I think there have been a couple of threads concerning the very same issue. Do a search of this site and in the meantime I'll try to take a look at your drawing as soon as I get a free moment. I have a tank fabrication drawing some engineer is hot to get his hands on.
Thank you ReMark.
i will search again , using more keywords. my previous search was unsuccessful.
It was quite the process just to download your drawing. That's the good news. The bad news is although I can see the buffer tank on my screen your drawing has locked up AutoCAD so for the moment I can't analyze it.
sorry for the run around to download. man i have been getting quite frustrated lately with this drawing, one moment it opens like a charm next it hangs like a fruit bat.
And hang it did.
Have you run any (or all) of these commands on the drawing?
Overkill
-Purge > Regapps (the dash is required before the command name)
-Purge > All
Audit (answer "yes" to fix database errors)
multiple times , just to make sure.:)
i have installed the AutoCAD_2017_Model_Documentation_Hotfix_64bit. i have encountered any issues with my current model,
im working through the rest now
have not, sorry.
Edited by DonovanPorter
