comet712 Posted October 10, 2017 Posted October 10, 2017 Hi, I'm looking for a routine where I can have auto dimension from multiple selected points to a line perpendicular to the points. Thank you in advance. Dimension from Point to line.dwg Quote
BIGAL Posted October 10, 2017 Posted October 10, 2017 Here is a start for you, change the line to a dim command, next step is to pick all points and do in one go. Please have a go at modifying. (setq oldsnap (getvar 'osmode)) (setq obj (vlax-ename->vla-object (car (entsel "\nPick line object")))) (while (setq pt (getpoint "pick point")) (setq pt2 (vlax-curve-getClosestPointTo obj pt acextendnone)) (setvar 'osmode 0) (command "line" pt pt2 "") (setvar 'osmode oldsnap) ) Quote
comet712 Posted October 12, 2017 Author Posted October 12, 2017 Hi BIGAL, Thank you for your reply. However I have no background on LISP Programming. I have tried my best to modify by changing the line to dim command as below. Still couldn't get it working though. Would you mind pointing out where went wrong? (defun c:try2 () (setq oldsnap (getvar 'osmode)) (setq obj (vlax-ename->vla-object (car (entsel "\nPick line object")))) (while (setq pt (getpoint "pick point")) (setq pt2 (vlax-curve-getClosestPointTo obj pt acextendnone)) (setvar 'osmode 0) (command ".DIMLINEAR" pt pt2 "") (setvar 'osmode oldsnap) ) ) Quote
BIGAL Posted October 13, 2017 Posted October 13, 2017 Very simple fix dim expects an offset point so (command ".DIMLINEAR" pt pt2 pt ) Quote
Kumar1 Posted Wednesday at 12:33 PM Posted Wednesday at 12:33 PM auto dimensioning by selecting multiple points and one line object Quote
devitg Posted Wednesday at 03:48 PM Posted Wednesday at 03:48 PM 3 hours ago, Kumar1 said: auto dimensioning by selecting multiple points and one line object @Kumar1 please upload a sample.dwg with, at least, 2 o3 dim as you need it to be Quote
Kumar1 Posted yesterday at 09:20 AM Posted yesterday at 09:20 AM On 10/17/2017 at 3:00 PM, comet712 said: Thanks BIGAL! this lisp is fine, but instead of picking each point, can we write a lisp routine to select multiple points and write dimension automatically. Quote
Kumar1 Posted yesterday at 09:56 AM Posted yesterday at 09:56 AM 18 hours ago, devitg said: @Kumar1 please upload a sample.dwg with, at least, 2 o3 dim as you need it to be this lisp is fine, but instead of picking each point, can we write a lisp routine to select multiple points and write dimension automatically. Sample File uploaded above. Quote
devitg Posted 23 hours ago Posted 23 hours ago 5 hours ago, Kumar1 said: this lisp is fine, but instead of picking each point, can we write a lisp routine to select multiple points and write dimension automatically. Sample File uploaded above. @Kumar1 please make or send a real dwg , with points-layer, line-layer, dim-layer and a new dimstyle not an overrided style, so all variables system are stated . Like the first DWG posted at this topic Dimension from Point to line.dwg Quote
pkenewell Posted 23 hours ago Posted 23 hours ago (edited) Here is a boiled down simple version with no error testing. It assumes that the dimensions will run on the same angle as the angle between the point and the curve segment: ;; Created by P. Kenewell 1/22/2026 (defun c:dim2pts (/ ep i p1 p2 p3 ss) (if (and (progn (princ "\nSelect Points to Dimension: ") (setq ss (ssget '((0 . "POINT,INSERT")))) ) (setq ep (entsel "\nSelect a curve to Dimension to: ")) ) (repeat (setq i (sslength ss)) (setq p1 (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) p2 (vlax-curve-getclosestpointto (vlax-ename->vla-object (car ep)) p1) p3 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2)) ) (command "._dimrotated" (* (/ (angle p1 p2) pi) 180.0) "_non" p1 "_non" p2 "_non" p3) ) ) (princ) ) Example Screenshots: Edited 1 hour ago by pkenewell Removed unnecessary (progn...). Updated point selection to include Block References. 2 Quote
Kumar1 Posted 2 hours ago Posted 2 hours ago Auto dimensiong - Project 1.dwg dimensions to be added as shown in the dwg by selecting multiple points and lines near by. Quote
Kumar1 Posted 1 hour ago Posted 1 hour ago 28 minutes ago, Kumar1 said: Auto dimensiong - Project 1.dwg dimensions to be added as shown in the dwg by selecting multiple points and lines near by. dimension to be perpendicular to the lines nearby Quote
pkenewell Posted 1 hour ago Posted 1 hour ago (edited) @Kumar1 I'm afraid your not going to get a completely automated solution. It might be possible, I'm not sure, but would take a great deal more code to sort and determine the closest curves. This is something I don't have time to write for you. The solution I gave you works if you select the points, then the curve for each set of dims. I leave it to you to sort out what you want from our examples. P.S. Some of your "points" are actually block references, you should better represent what you want. I am updating the code above to include block references, which will get their insertion point.. Edited 1 hour ago by pkenewell Quote
