IronHorse Posted October 23, 2017 Posted October 23, 2017 On attached screenshot I try to add radius 1909,8 + height 150, But It do not work. I have tried mm, ul and deg but It doesent allow me. What I do wrong? Quote
ecshclark Posted October 31, 2017 Posted October 31, 2017 Your equation can not add up to more than 360 degrees. Quote
JD Mather Posted November 16, 2017 Posted November 16, 2017 On attached screenshot I try to add radius 1909,8 + height 150, But It do not work. I have tried mm, ul and deg but It doesent allow me. What I do wrong? d66 and d60 are in mm units, angles are given as degrees. Therefore you must right your equation to cancel out the mm units, just like in HS math class. Quote
