gerardo2m Posted October 27, 2017 Posted October 27, 2017 Hi. I need to assign the name to a variable, but taking the name of an element from a LIST. Example: Command: (setq TEMPORAL '*Blocks*) *BLOCKS* Command: (set TEMPORAL 250) 250 Command: !TEMPORAL *BLOCKS* Command: !*blocks* 250 Until here Ok. Now it is required that the name of the variable is taken from an element in a LIST: (setq x1 (list "*blocks*" "*layers")) ("*blocks*" "*layers") Command: (set TEMPORAL (nth 0 x1)) "*blocks*" I do not require the value "*blocks*" to be assigned to the TEMPORAL symbol, but symbol *BLOCKS* is assigned. How can this be done? Regards. gerardo2m. Quote
Lee Mac Posted October 27, 2017 Posted October 27, 2017 Either: (setq x1 '(*blocks* *layers*)) (setq TEMPORAL (car x1)) (set TEMPORAL 250) Or: (setq x1 (list '*blocks* '*layers*)) (setq TEMPORAL (car x1)) (set TEMPORAL 250) Or: (setq x1 (list "*blocks*" "*layers*")) (setq TEMPORAL (read (car x1))) (set TEMPORAL 250) Looks like a homework assignment to me. Quote
gerardo2m Posted October 28, 2017 Author Posted October 28, 2017 I aprecciate you support Lee, thanks. It isn't homework, I was stuck with that part of the code to use MAPCAR and LAMBDA for extract info of drawing's Colecctions. Quote
