I've been at this for some time but for some reason my CAD is acting up on me today and making me feel stupid. I model up a shape in top view. I then to get right side view to rotate the object down but for some reason autocad will not allow it. The object just flicks back and forth from the left to the right of the screen. Anybody have a fix for this? I'm under a time crunch. Thanks.
Can you attach a copy of the drawing? Need a .dwg not an image file. If the file size is too large upload to a file sharing website like DropBox and post a link to it here.
Did you solve your problem? Never heard back from you.
Edited by ReMark
Are you using AutoCAD 2008?
How are you changing to side view?
Perhaps, after you changed from top view to side view, you forgot to set UCS to be aligned with new side view... So command is UCS -> V...
