Hi all,
I've been trying to create a macro to rotate an object around a centerpoint while copying it. If doing this the long way my actions are as follows:
rotate
enter
select object
enter
center
enter
select basepoint
copy
enter
reference
enter
center
specify reference angle
specify second point
specify new angle
can somebody give me some guidance? Is it not possible to use center osnap command in a macro? Should this be done with a LISP?
Thanks!
Doing it in a different order may be easier. Pick object 1st.
(defun c:rocop ( / ss pt1 pt2 pt3)
(setq ss (ssget))
(setq pt1 (getpoint "pick Centre pt"))
(setq pt2 (getpoint pt1  "1st angle point"))
(setq pt3 (getpoint pt1 "2nd angle point"))
(command "rotate" ss "" pt1 "Copy" "R" pt1 pt2 pt3)
Thanks BIGAL. This is close to what I'm trying to achieve but is missing a couple steps I think that make it function the way I want it to. Below is a capture of what i need it to do:
https://i.imgur.com/j62ryJx.gifv
Hopefully this is more clear. Is this something achievable?
Thanks!
Any reason this has to be a macro/lisp?
Can you not just use the polar array command?
Polar array would work for the example I showed, however I really only meant it as an example to demonstrate the process. I use this often on larger scales with multiple increments, etc. This is the best way I've found over the years for the particular application but finally decided to try and speed it up by eliminating some key stroke, if possible.
Its totally different to what you asked for, pick circle, pick object, pick chord 2 points, how many required clockwise or anti. It also depends a bit on how say that square is drawn is it the corners that touch the circle ? This is a Gear type lisp solution using pitch for gear spacing. Its not that hard to do anyway had a few minutes.
; simple rotatecopy
; By Alan H nov 2017
(setq howmany (Getint "Enter How many"))
(setq ss (ssget))
(if (= howmany 1)(princ "1")
(repeat (- howmany 1)
(command "rotate" (entlast) "" pt1 "Copy" "R" pt1 pt2 pt3)
BIGAL, thanks! That actually work better than what I was asking for since I can specify multiple copies as opposed to copying one, then copying 2, then copying 4, etc. I very much appreciate you taking the time to respond and write this little script up for me. :winner:
