Prasanna Posted November 14, 2017 Posted November 14, 2017 Hi, I'm new to AutoCAD. I have 700 drawings in AutoCAD. I have to enter "Checker" value in the drawing title block. For all the drawings, its the same value. How to I automate this? I don't want to open manually individual drawing and fill the value. Any macro available for this? Please help. Regards, Prasanna.A Quote
Dadgad Posted November 14, 2017 Posted November 14, 2017 Welcome to CADTutor Prasanna. I would suggest you use the following wonderful lisp by forum member Lee Mac. http://www.lee-mac.com/bfind.html It is the cat's pajamas. Thanks Lee! Once you read the instructions on how to drive it, you will be able to correct all of them in a couple of minutes, without needing to open any of them. Quote
SLW210 Posted November 14, 2017 Posted November 14, 2017 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote
Lee Mac Posted November 14, 2017 Posted November 14, 2017 I have 700 drawings in AutoCAD. I have to enter "Checker" value in the drawing title block. For all the drawings, its the same value. Assuming your titleblock is attributed, you could use my Batch Attribute Editor application to perform this task. @Dadgad, thank you for your recommendation. Quote
