TunzaGibbo Posted November 16, 2017 Posted November 16, 2017 This the last bit of a routine I'm trying to create. Its very simple in its overall intent It just adds a line of text inside a rectangle. The TCIRCLE (Express Tools) command is being executed and then I have to manually accept or change the defaults. How can I write this last bit of TCIRCLE to have it run through automatically? Thanks (setvar "cecolor" "6") (command "_.text" "Justify" "C" inspt "3.5" "0" a ) ((c:tcircle) a "" "0.35" "" R "" "" ) (princ) ) Quote
BIGAL Posted November 16, 2017 Posted November 16, 2017 This may be like extrim you can run it from a lisp but it use a differrent command "ETRIM" This is the simplest way http://www.lee-mac.com/boxtext.html Quote
TunzaGibbo Posted November 16, 2017 Author Posted November 16, 2017 Still having the same thing with boxtext. Works good on its own but I don't know how to put it into my lisp file to run at the end. same as tcircle Quote
Aftertouch Posted November 16, 2017 Posted November 16, 2017 Try this: (defun C:TEST ( / ) (setq SS1 (ssget "L")) (bns_tcircle SS1 "Variable" "Rectangles" nil 0.35) (princ) ) Quote
TunzaGibbo Posted November 16, 2017 Author Posted November 16, 2017 Thank you for your reply. I have tried to enter your text but I can't get it to work. Would you be so kind as to enter it in the code I submitted? Quote
Aftertouch Posted November 16, 2017 Posted November 16, 2017 Here you go: Alto i think your 'text' command line is wrong, since your given arguments are not able in the command... (defun C:test ( / oldcecolor inspt ) (setq oldcecolor (getvar "CECOLOR")) (setvar "cecolor" "6") (setq inspt (getpoint)) (command "_.text" "Justify" "C" inspt "3.5" "0" "") (setq SS1 (ssget "L")) (if (not bns_tcircle) (load "acettxt.lsp")) (bns_tcircle SS1 "Variable" "Rectangles" nil 0.35) (setvar "CECOLOR" oldcecolor) (princ) ) Quote
BIGAL Posted November 17, 2017 Posted November 17, 2017 This may be like extrim you can run it from a lisp but it use a differrent command "ETRIM" Aftertouch for the dummys like me Tcircle uses a differrent command "bns_tcircle" if you want to use lisp Quote
TunzaGibbo Posted December 8, 2017 Author Posted December 8, 2017 Thank you very much Aftertouch your code worked perfect Quote
