nicolas Posted November 19, 2017 Posted November 19, 2017 Hi, I need to make a custom-made barrel thread 24mm. long with size 8 or 10mm and pitch of 6 mm. How can this be done in Inventor? Thanks. Quote
gazza_au Posted November 20, 2017 Posted November 20, 2017 Open the thread.xls (Design Data folder of Inventor installation) file in Excel and go to the "ANSI Metric M Profile" (metric) tabs. Add rows with thread sizes you want to add. Restart Inventor to accept changes. I would then download cool orange thread modeler from the add ons and cut the thread. https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2540506896683021779&appLang=en&os=Win32_64 Quote
JD Mather Posted November 21, 2017 Posted November 21, 2017 I would create cylinder. I would sketch cutting tool. I would then use the Coil command with Cut option - just like out on the shop floor. Quote
nicolas Posted November 29, 2017 Author Posted November 29, 2017 Thank you very much. Will act upon your comments this evening and will be back to you tomorrow. Quote
