Lay off Filters fail - can't determine reason
Hello-
This is part of a larger cleaning the drawing script, but for some reason it is failing to turn off the layers based on the filters. Any input would be great, I think it is a super simple mess up on my part....I can't find it though.
It does call some other lisp routines within the program that are working great.
(DEFUN C:XCLEAN	()	; 	Defines Command Prompt Function Name
(Prompt "\n***  Working, Please wait purge and auditting drawing......\n")	;	Feedback to user
(getvar "cmdecho")	;	Get cmd echo variable status
(setvar "cmdecho" 0)	;	Turn off command line
(getvar "Nomutt")	;	Get Nomutt variable status
(setvar "Nomutt" 1)	;	Turn off command line
;;	UNLOCK ALL	;;
(command "-layer" "ON" "*" "thaw" "*"	"u" "*" "color" "t" "255,0,255"	"*" \e )	; 	All layers on, unfrozen and unlock all layers, set color to magenta of all layers
;;	DELETE ALL DIMENSIONS	;;
 	(command "_.erase" (ssget "X" '((0 . "DIMENSION,LEADER"))) "")
;;	SPECIALIZED BURST - SEE SCRIPTS BELOW ;;
(C:DEMO)
(C:DEMO)
(C:DEMO)
;; DELETE ALL LAYOUTS	;;
(vl-load-com)
(setq layouts
(vla-get-layouts
(vla-get-activedocument (vlax-get-acad-object))
(mapcar '(lambda (layout)
(vla-delete (vla-item layouts layout))
(layoutlist)
;; SET ALL TO BY LAYER
(command "LAYON" "LAYTHW" "SETBYLAYER" "ALL" "" "Y" "Y")	;	SET ALL TO BY LAYER
;;	PURGE AND AUDIT	;;
(command "-purge" "All" "*" "N" \e)	;	Purge all unused
(command "tilemode" "1")	; 	Makes Model Space Current
(command "zoom" "e")	; 	Zoom Extents
(command "tilemode" "0")	; 	Makes Paper Space Current
(command "_qsave")	; 	Save File
(command "-purge" "All" "*" "N")	; 	Purge all unused
(command "-UNITS" "4" "16" "1" "0" "90" "N" \e)	; 	Sets unit Architectual, 1/16" Precision, Decimal Degrees with no decimal spaces, Angle Zero at top of screen
  ;;	CHANGE ALL HATCH TO COLOR 8
(command "_.chprop"
(ssget "x" (list (cons 0 "HATCH")))
"Color"
8
[color="red"]   	;;	TURN OFF SPECIFIC LAYERS
(command "-LAYER" "OFF" "*WALL-IDEN*" \e)
(command "-LAYER" "OFF" "*DOOR-IDEN*" \e)
(command "-LAYER" "OFF" "*DIMS*,*DEFPOINT*" \e)[/color]
;;	SET TO COLOR 8 BY LAYER Name
(command "-LAYER" "COLOR" 8 "*TREE*,*BUSH*,*PLANTS*" \e)
(command "-LAYER" "COLOR" 8 "*LTS*,*LITE*,*LIGHT*" \e)
(command "-LAYER" "COLOR" 8 "*FURN*,*DETL*" \e)
(command "-LAYER" "COLOR" 8 "*CURB*,*PARK*" \e)
(command "-LAYER" "COLOR" 8 "*PITCH*,*SLOPE*" \e)
(command "-LAYER" "COLOR" 8 "*GRID*" \e)
(command "-LAYER" "COLOR" 8 "*ANNO*,*IDEN*,*PATT*" \e)
(setvar "Nomutt" 0)	;	Turn on command line
(Prompt "\n******************************************\n")	;	Feedback to user
(Prompt "\n******* XCLEAN SCRIPT COMPLETE	*********\n")	;	Feedback to user
(gc)	;	Free ram resources
Edited by noochstyle
Identify Problem Area with Red Highlight
Try to use freeze? This work here for me: (command "-LAYER" "FREEZE" "*WALL-IDEN*" nil)
That works, just curious that the OFF doesn't but the "Freeze" does....
There should be no difference between nil and \e in this situation correct?
And thank you!!! Should have opened with that part.
I've never seen \e used in a command call so don't know if they are the same. Most of this layer stuff could be automated without any command. Here is a quick example to change layer colors:
(vl-load-com)
(defun layer2color (pattern color / n)
 (vlax-for l (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
   (if	(wcmatch (setq n (strcase (vla-get-name l))) (strcase pattern))
     (vla-put-color l color)
(layer2color
 "*TREE*,*BUSH*,*PLANTS*,*LTS*,*LITE*,*LIGHT*,*FURN*,*DETL*,*CURB*,*PARK*,*PITCH*,*SLOPE*,*ANNO*,*IDEN*,*PATT*"
 8
(defun layer2colorvanilla (pattern color / e l n)
 (while (setq l (tblnext "layer" (null l)))
   (and (setq n (cdr (assoc 2 l)))
 (wcmatch (strcase n) (strcase pattern))
 (setq e (tblobjname "layer" n))
 (setq e (entmod (append (entget e) (list (cons 62 color)))))
(layer2colorvanilla
 8
And you're welcome :)
Edited by ronjonp
 ;; Make mask layer colors 255,255,255
(layer2colorvanilla
 8
This works great, and probably much faster to make the change than passing the commands through. I don't really understand the masking part. I used the definition the same way for the first part but took at the "vanilla" part (like the name choice though, ha-ha).
I just pass it using this:
(vl-load-com)
   (if	(wcmatch (setq n (strcase (vla-get-name l))) pattern)
(layer2color
"*TREE*,*BUSH*,*PLANTS*,*LTS*,*LITE*,*LIGHT*,*FURN*,*DETL*,*CURB*,*PARK*,*PITCH*,*SLOPE*,*ANNO*,*IDEN*,*PATT*,*GENM*"
8
Here's some more to mull over :)
The mask note was something I had for different code .. you can disregard it.
(defun c:layerschtuff (/ doc n s)
 ;; To modelspace
 (setvar 'tilemode 1)
 (vlax-for l (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object))))
   ;; Unlock layers
   (vl-catch-all-apply 'vla-put-lock (list l :vlax-false))
   ;; Color magenta
   (vla-put-color l 6)
   ;; Color 8
   (if
     (wcmatch
n
      (vla-put-color l
   ;; Freeze layers
   (if	(wcmatch n "*WALL-IDEN*,*DOOR-IDEN*,*DIMS*,*DEFPOINT*")
     (vl-catch-all-apply 'vla-put-freeze (list l :vlax-true))
 ;; Delete dims and leaders
 (and (setq s (ssget "X" '((0 . "DIMENSION,LEADER")))) (mapcar 'entdel (mapcar 'cadr (ssnamex s))))
 ;; Delete layouts
 (vlax-for l (vla-get-layouts doc) (vl-catch-all-apply 'vla-delete (list l)))
(c:layerschtuff)
Is it that much more efficient to use what I VBA/Activex in lieu of passing the commands?
does the mapcar make the deleting dimensions recursive through all entities or will the command need to be run multiple times to eliminate those dimensions within burst entities after they are burst?
You are going to send me down the coding rabbit whole, ha-ha.
What I like about NOT using command calls is the consistency of code working between version of AutoCAD .. and yes generally it is much faster. As far as the deleting dims after exploding, you'd need to repeat x times while bursting .. something like so.
 ;; Repeat 10 times exploding block and deleting dims
(repeat 10
   (and (setq s (ssget "_X" '((0 . "insert") (410 . "Model")))) (command "_.explode" s))
   (and (setq s (ssget "_X" '((0 . "DIMENSION,LEADER") (410 . "Model"))))
I hope so .. once you start understanding the code it gets quite addictive! :)
That is cool the repeat command! Definitely didn't know about that one. Well you re-wrote a nice chunk of my code into a better format....much appreciated. I think I might use the repeat as well for my purge command. I am thinking to just run the dim delete routine right before the last purge. I was just trying to speed things up by deleting as much of the unneeded stuff as possible.
Ok I am sold.
(vla-purgeall (vla-get-activeDocument (vlax-get-acad-object)))
SILENT AND FASTER THAN:
(command "-purge" "All" "*" "N" nil)
RONJONP - Thanks for your help, code runs 100x cleaner and much faster. Command line is clean an uninterrupted. Love the change.
I might try and change the following lines, but for now I am going leave them as is [i am an electrical engineer by trade not a programmer and should get to my daily tasks =) ]
Here you go if you want to see the almost finished project. Going to start re-organizing my other scripts the same way. Appreciate the lesson!
(Prompt "\n***  Working, Please wait working on the drawing......\n")	;	Feedback to user
;;	TURN OFF COMMAND LINE
;;	UNLOCK ALL	;;
(command "-layer" "ON" "*" "thaw" "*" "u" "*" "color" "t" "255,0,255"	"*" NIL )	; 	All layers on, unfrozen and unlock all layers, set color to magenta of all layers
(repeat 4
(C:DEMO)
;; To modelspace
;; Unlock layers
;; Color magenta
   (vla-put-color l 6)
;; LAYERS TO CHANGE TO COLOR 8 BY FILTER
   (if
     (wcmatch
n
"*TREE*,*BUSH*,*PLANTS*,*LTS*,*LITE*,*LIGHT*,*FURN*,*DETL*,*CURB*,*PARK*,*PITCH*,*SLOPE*,*ANNO*,*IDEN*,*PATT*,*GRID*"
      (vla-put-color l
;; LAYERS TO FREEZE BY FILTER
   (if	(wcmatch n "*WALL-IDEN*,*DOOR-IDEN*,*DIM*,*DEFPOINT*")
;; Delete layouts
(command "SETBYLAYER" "ALL" "" "Y" "Y")	;	SET ALL TO BY LAYER
(setvar 'tilemode 1)	; 	Makes Model Space Current
(setvar 'tilemode 0)	; 	Makes Paper Space Current
;;	PURGE 2X
(repeat 2	;	Purge 5x
(vla-purgeall (vla-get-activeDocument (vlax-get-acad-object)))	;	Purge all unused
(command "_.chprop"
"Color"
8
;;	PURGE 3X
(repeat 3	;	Purge 5x
;;	SAVE DRAWING
;;	TURN ON COMMAND LINE
(setvar "Nomutt" 0)	;	Turn ON command line
(setvar "cmdecho" 1)	;	Turn ON command line
Only a few commands left to convert (thawing all layers - which I will attack tonight):
A challenger for another day. Made leaps and bounds with your input, thanks again!
John
Here's some more input .. I'm off for the holiday enjoy the puzzle!
(defun c:xclean	(/ doc n s)		;<- localize variables!
 (prompt "\n***  Working, Please wait working on the drawing......\n") ;	Feedback to user
 ;;(getvar "cmdecho")			;	Get cmd echo variable status
 ;;(getvar "Nomutt")			;	Get Nomutt variable status
 ;;	UNLOCK ALL	;;
 ;;(command "-layer" "ON" "*" "thaw" "*" "u" "*" "color" "t" "255,0,255" "*" nil)
 (repeat 4 (c:demo))
 ;; To modelspace
   ;; Unlock layer
   ;; Turn on layer
   (vl-catch-all-apply 'vla-put-layeron (list l :vlax-true))
   ;; Thaw layer
   (vl-catch-all-apply 'vla-put-freeze (list l :vlax-false))
   ;; Color magenta
   (vla-put-color l 6)
   (if
     (wcmatch
n
      (vla-put-color l
 ;; Delete layouts
 ;; RJP - replaced with vla .. although not sure of speed performance (command "zoom" "e")			; 	Zoom Extents
 (vla-zoomextents (vlax-get-acad-object))
 ;; RJP - replaced with vla .. although not sure of speed performance (command "_qsave")			; 	Save File
 (vla-save doc)
 ;; RJP - (setvar 'lunits 4) = -units 4 .. I'm sure there are variables for the other settings but I've had too much beer tonight
 (setvar 'lunits 4)
 (command "-UNITS" "4" "16" "1" "0" "90" "N" nil)
 ;; RJP - Vla-purgeall may not have the same effect as the command call ( test it! )
 ;;	PURGE 2X
 (repeat 2 (vla-purgeall doc))
 ;; RJP - check that you have hatch before calling the command .. converted to entmod for color
 (and (setq s (ssget "x" (list (cons 0 "HATCH"))))
      (mapcar '(lambda (x) (entmod (append (entget x) '((62 . )))) (mapcar 'cadr (ssnamex s)))
 ;; RJP - Vla-purgeall may not have the same effect as the command call ( test it! ) maybe just purge all at the end? USe 'doc' defined above
 (repeat 3 (vla-purgeall doc))
 (vla-save doc)			; 	Save File
 (prompt "\n******************************************\n") ;	Feedback to user
 (prompt "\n******* XCLEAN SCRIPT COMPLETE	*********\n") ;	Feedback to user
