[How to] Import .xls text with X and Y coordinate into AutoCAD
Hi there, im using AutoCAD 2017 and I have a problem.
I used DATAEXTRACTION command to create an excel file X and Y coordinate of mtext.
When finished edit .xls file, I want to import it into AutoCAD again but i dont know how?
Pls help me
It's real easy you use the concatenation commnand in excel
=concatenation ("text" ,b1,",",c1," 90 2.5")
Where b1 is x and c1 is y
Just copy the column to the autocadcommand line
Sorry typed on IPad may need a check.
Just look at command line for manual entry
Edited by BIGAL
