I'm trying to write a lisp that will make all xrefs in a drawing be set to relative upon save. I have a save reactor created but I can't get the lisp routine to work.
Save Reactor:
(defun AtSaveCommand (calling-reactor b)
(if
 (or
 (= (car b) "QSAVE")
 (= (car b) "SAVEAS")
 (= (car b) "SAVE")
(xrefpath)
(defun loadTheSaveReactor ()
(vl-load-com)
(if *FileOnSave* (vlr-remove *FileOnSave*))
(setq *FileOnSave*
(vlr-command-reactor nil '((:vlr-commandwillStart . AtSaveCommand)))
(loadTheSaveReactor)
Lisp Routine
(defun xrefpath ()
(COMMAND "redir" "*" "")
GRRRRRR!!!
not the answer I wanted But thems the breaks!
As quoted from AfraLISP:
A word of warning!!! Did you notice how I used ActiveX statements and functions to "Save" and "SaveAs". You cannot use interactive functions from within a reactor as AutoCAD may still be processing a command at the time the event is triggered. Therefore, avoid the use of input-acquisition methods such as "getPoint", "ensel", and "getkword", as well as "selection set" operations and the "command" function.
  • 8 years later...
Try this:
Point of reference here: https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-ActiveX/files/GUID-E13A580D-04CA-46C1-B807-95BB461A0A57-htm.html
;; AtSaveCommand
;; loadTheSaveReactor
;; Found here: http://forums.augi.com/showthread.php?93534-Run-lisp-when-closing-drawing&p=926895&viewfull=1#post926895
(if
	(or
		(= (car b) "QSAVE")
		(= (car b) "SAVE")
		(setq acadObj (vlax-get-acad-object))
		(setq activeDoc (vla-get-ActiveDocument acadObj))
		;; Get activeDoc Help: https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-ActiveX/files/GUID-161FD7E5-B739-4E09-8430-BA04A6298703-htm.html
		(if	(= (vla-get-ActiveSpace activeDoc) 1)
				(vla-SendCommand activeDoc (strcat "._TEXTTOFRONT A "))
				; (vla-Regen activeDoc acAllViewports)
				; (vla-SendCommand activeDoc (strcat "_REGEN "))
				; (princ "\nSwitching to ModelSpace & Back, 1 sec...")(princ)
				;; (run your command here)
				;; Code changed from here
				;; YOu can run a command like so: See help here:
				;; https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-ActiveX/files/GUID-E13A580D-04CA-46C1-B807-95BB461A0A57-htm.html
				(vla-SendCommand activeDoc (strcat "._TILEMODE 1 "))
				(vla-SendCommand activeDoc (strcat "._TILEMODE 0 "))
(setq *FileOnSave*
(vl-load-com)
3dwannab,
Use :VLR-DWG-Reactor with :VLR-beginSave event and also either globalize the acDoc variable, outside the callback function, either localise it inside the callback func.
Also that thread is from 2009, why are you replying?
3dwannab,
I was just trying to help others ;) Seeing as the Thread is about running a command through a reactor.
Thanks for the pointer here. It's working as it should. As sometimes that old code ran only once. (Probably due to the fact I didn't localise the vars.
(defun BeginSave (objReactor lstDataBaseAndName / acadObj activeDoc cmd)
(setq cmd (getvar "cmdecho"))
(setvar 'cmdecho 0)
		(princ "\nSwitching to ModelSpace & Back, 1 sec...\n")(princ)
(setvar 'cmdecho cmd)
(if (not rxnBeginSave)
(setq rxnBeginSave (VLR-DWG-Reactor nil '((:VLR-beginSave . BeginSave ))))
(princ "\nDrawOrder_Reactor.lsp Loaded..")(princ)
Scrap that last code:
It behaves badly as ACAD fires of a SAVE when you copy opjects. So VLR-DWG-Reactor and :VLR-beginSave will not work.
Instead, it's better to use vlr-command-reactor and :vlr-commandwillstart to monitor the commandline for your commands you want to fire the event on like:
	(if (wcmatch (strcase (car arg)) "SAVE,QSAVE,SAVEAS,PLOT")
	(setdraworder)
Here are two different working solutions, the first one is the commandline TEXTTOFRONT one. Note: It's best to use vla-SendCommand throughout your progn otherwise ACAD seems to go into a nasty loop.
And the second is a modified version of LeeMacs reactor to work with text and dim objs found here. I'm running with that as it doesn't require an additional save to keep the Draworder. (Another downside of (vla-SendCommand) I suppose).
My command call DrawOrder Reactor using TEXTTOFRONT
;; setdraworder
;; You can run a command like so: See help here:
;; by 3dwannab to work with all HATCH, TEXT, LEADER and DIM objects
;; Known Bugs: Needs additional Save to Save DRAWORDER of Objects
(defun setdraworder ( /
acadObj
doc
activeSpe
(setq doc (vla-get-ActiveDocument acadObj))
(setq activeSpe (vla-get-ActiveSpace doc))
(if	(= 1 activeSpe)
	(vla-SendCommand doc (strcat "._TEXTTOFRONT A "))
	(vla-SendCommand doc (strcat "._HATCHTOBACK "))
	(vla-SendCommand doc (strcat "._TILEMODE 1 "))
	(vla-SendCommand doc (strcat "._TILEMODE 0 "))
(vla-Regen doc acActiveViewport)
(princ "\n >>> Draworder Reactor is Running ...\n")(princ)
(defun draworder:callback ( obj arg )
	(setdraworder)
(vl-load-com)
(if (null draworder:reactor)
	(setq draworder:reactor (vlr-command-reactor nil '((:vlr-commandwillstart . draworder:callback))))
LeeMac Mod:
Edited so that user can turn off and on the reactor with: setdraworder-off & setdraworder-on
Works with commands: SAVE,QSAVE,SAVEAS,PLOT,PUBLISH
;; Re: Send all hatch/images to background prior to printing & Saving
;; by LeeMac
;; https://www.theswamp.org/index.php?PHPSESSID=klskia7od2ku3u3kf9o6n4nl13&topic=43352.msg507568#msg507568
;; Edited on 10.04.17 by 3dwannab to work with all TEXT, LEADER and DIM objects
exd
ls1
ls2
ls3
obn
sor
spc
(if
(setq
	spc (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
	exd (vla-getextensiondictionary spc)
	sor (cond ((catchapply 'vla-getobject (list exd "acad_sortents")))
		((catchapply 'vla-addobject (list exd "acad_sortents" "acdbsortentstable")))
	(vlax-for obj spc
		(cond
			(   (= "AcDbHatch" (setq obn (vla-get-objectname obj)))
				(setq ls1 (cons obj ls1))
			(   (= "AcDbRasterImage" obn)
				(setq ls2 (cons obj ls2))
			(   (= (wcmatch (vla-get-objectname obj) "*Dim*,*Leader*,*Text*") (setq obn (wcmatch (vla-get-objectname obj) "*Dim*,*Leader*,*Text*")))
				(if (wcmatch (vla-get-objectname obj) "*Dim*,*Leader*,*Text*")
					(setq ls3 (cons obj ls3))
	(if ls1 (vlax-invoke sor 'movetobottom ls1))
	(if ls2 (vlax-invoke sor 'movetobottom ls2))
	(if ls3 (vlax-invoke sor 'movetoTop ls3))
	(princ "\n >>> Draworder Reactor was successful ...\n")(princ)
(princ "\nUnable to retrieve Sortents Table.")
(defun catchapply ( fun arg / rtn )
(if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fun arg)))) rtn)
(defun c:setdraworder-on ( )
(if (= 'vlr-command-reactor (type draworder:reactor))
	(if (vlr-added-p draworder:reactor)
		(princ "\nSet Draworder reactor already running.")
			(vlr-add draworder:reactor)
			(princ "\nSet Draworder reactor enabled.")
			(vlr-command-reactor "setdraworder-reactor"
(defun c:setdraworder-off ( )
		(vlr-remove draworder:reactor)
		(setq draworder:reactor nil)
		(princ "\nSet Draworder reactor disabled.")
	(princ "\nSet Draworder reactor not running.")
(if (wcmatch (strcase (car arg)) "SAVE,QSAVE,SAVEAS,PLOT,PUBLISH")
	(setdraworder)
(vl-load-com)
(princ "\n :: Draworder Reactor was loaded ::\n")(princ)
Edited by 3dwannab
Code amendment
