Flat pattern error
I'm a bit new to Inventor and created a basic sheet metal part with flanges and am receiving the error message "Could not split between bend and plate..."
Could someone help with this?
B0625-44-003.zip
  • 2 weeks later...
I haven't downloaded your zip file, though you may consider setting up your sheet metal defaults, and rather than using the bend command, try using the flange command.
  • 3 weeks later...
You've created Sheet Metal Part in 3D Modelling Environment, instead of "Extrude Cut" you should use Cut Across Bend
