Getpoint & repeat
leong1221
Hi Guys,
I am writing a lisp using Getpoint (mouse input) and sometime i need 1 point sometime 2 sometime 3 and setq each point to pt1 pt2 pt3.
If i want to make this lisp keep asking Getpoint until user press the spacebar to proceed to next step, should i use repeat??
Hi,
You can use While function.
(while (setq pt (getpoint "\nSpecify a point :"))
 (setq pts (cons pt pts))
This will assign to a variable pt1, pt2, pt3 etc until enter/spacebar is pressed.
(defun c:loop2 (/ pt ptlist cnt num)
 (setq ptlist nil)
 (while (setq pt (getpoint "\nEnter Point or RETURN when done: "))
   (append ptlist (list pt)))
 ) ;_ end of while
 (setq cnt (length ptlist))
 (setq num (+ cnt 1))
 (repeat cnt
   (set (read (strcat "pt" (itoa (setq num (- num 1))))) (last ptlist))
   (setq ptlist (vl-remove (last ptlist) ptlist))
 ) ;_ end of repeat
) ;_ end of defun
:P Recursive:
; (getpoints nil "\n>>> Specify point: ")
(defun getpoints ( p m )
 (cond ((not (setq p (apply 'getpoint (append (if p (list p)) (if m (list m)))))) p) ((cons p (getpoints p m))))
); defun getpoints
