Output to Text File Without Dialog Box?
I have this snippet of code where you can output a file:
 (if (setq fn
            (getfiled "Save layer list as"
                      (strcat (vl-filename-base (getvar "dwgname")) ".txt")
                      "txt"
                      1
   (if (layer-list-fprint fn)
     (princ "\nLayer list created.")
     (princ "\nError: Layer list not created!")
What I want to do is to automatically output a text file with the file name the same as the .dwg (but with a ".txt" extension) and overwrite an existing file in one exists.
Can I do that without the dialog?
Greg
Getfiled is calling the dialog box, look at (getvar "dwgprefix") you can hard code the txt file to be in the same place as the dwg or put it where ever you like.
(setq fname (strcat (getvar "dwgprefix") (getvar "dwgname") ".txt"))
another example
; check that pdf directory exists
(setq dwgpre (strcat (getvar "dwgprefix") "\pdf"))
(if (= (vl-file-directory-p dwgpre) nil)
(vl-mkdir dwgpre)
(setq pdfname (strcat (getvar "dwgprefix") "pdf\\" dwgname "-" (getvar "ctab")))
That worked great BIGAL and thanks!
Also, I appreciate the bonus code.
Greg
