String Comparison - Does NOT Equal But Should
I have a routine that reads two files and reports if there are differences.
The data is place in "out1" for file 1 and "out2" for file 2.
As a test, I have it read the same file. It says that they are not equal.
When I do this it reports a "YES!!"
 (if (= out1 out1)
    (princ "\nYES!!")
    (princ "\nno.")
When I do this it reports a "no."
 (if (= out1 out2)
    (princ "\nYES!!")
    (princ "\nno.")
Any thoughts as to what is going on?
Below is the complete routine:
(defun c:ctf (/ fil fl i mycount out1 out2 rec)
 ;; String to List  -  Lee Mac
 ;; Separates a string using a given delimiter
 ;; str - [str] String to process
 ;; del - [str] Delimiter by which to separate the string
 ;; Returns: [lst] List of strings
 (defun lm:str->lst (str del / pos)
   (if    (setq pos (vl-string-search del str))
     (cons (substr str 1 pos) (lm:str->lst (substr str (+ pos 1 (strlen del))) del))
     (list str)
 )   ; End of lm:str->lst
 ; Read File 1
 (setq fl nil)
 (setq fil nil)
 (if (setq fl (open "C:\\Users\\ggleason\\Documents\\CADWorx\\CADWorx.Projects\\Exxon.Joliet.2015-151\\IsoLayers\\ExxonMobil.Iso.Border.Acad.v.2007.dwg.txt" "r"))
      (setq mycount 0)
      (while (setq fil (read-line fl))
         (setq mycount (1+ mycount))
         ; SYNTAX: (princ "\nMy Name is \nJohn")(princ)
         ; (princ mycount)(princ "\n")
         (setq out1 (cons (lm:str->lst fil "\t") out1))
      )   ; End of "While" loop
      (close fl)
      (princ (strcat (itoa mycount) " records read in File 1\n"))
 )   ; End of "If" statement for File 1
 ;; Reverse results to put them in correct order
 (setq out1 (reverse out1))
 ; End of File 1
 ; Read File 2
 (setq fl nil)
 (setq fil nil)
      (setq mycount 0)
         (setq out2 (cons (lm:str->lst fil "\t") out2))
      (close fl)
      (princ (strcat (itoa mycount) " records read in File 2\n"))
 )   ; End of "If" statement for File 2
 (setq out2 (reverse out2))
 ; End of File 2
         ; SYNTAX: (if (= 1 3) "YES!!" "no.")
 (if (= out1 out2)
    (princ "\nYES!!")
    (princ "\nno.")
 (princ "\n ------------------------------------------------")
 (princ "\n")
 (princ out1)
 (princ "\n")
 (princ out2)
)                    ; End of c:ctf
Greg
Is there some reason why you are not comparing each line as read from the two files ? I did code on a test file and it came back No.
Per the documentation, the '=' function should be used for numerical or string comparison, not for list comparison - observe:
_$ (= '(1 2 3) '(1 2 3))
nil
Instead, you should use the equal function.
_$ (equal '("a" "b" "c") '("a" "b" "c"))
T
Aside of Lee's most obvious suggestion (using the equal function), heres an alternative if one deals only with list of strings:
(vl-every '= '("a" "b" "c") '("a" "b" "c") '("a" "b" "c"))
hence:
(vl-every '= ListOfStrings1 ListOfStrings2 ListOfStrings3 ...)
and even:
(apply 'vl-every (cons '= ListOfStringLists))
Although I'd use equal myself, since it works with nested lists.
I would have like to have done that, but I was not sure how to go about it.
Greg
nil
T
Thank you for clearing that up.
Also, I appreciate all of the great information you put out there for us to learn from.
Greg
hence:
and even:
That is great information. Thank you.
Greg
There is a major difference between vl-every '= and equal
_$ (equal '("a" "b") '("a" "b" "c")) -> nil
_$ (vl-every '= '("a" "b") '("a" "b" "c")) -> T
Thanks for pointing this out, Stefan!
I've forgot that vl-every processes like mapcar.
So that suggestion should be used in conjunction with equal length check of the lists.
