Nm4553 Posted January 15, 2009 Posted January 15, 2009 I am currently using the MEP 2009 software. I am modeling in 3D and having problems with the hidden lines. For example, I am designing a chiller system, the chiller is a higher elevation than the pipe which I am connecting to it. The objects under the chiller are displayed as a hidden linetype automatically (different color, linetype, lineweight, etc.). Is there anyway to change these properties or even turn this feature off? Any input would be greatly appreciated! Quote
Siberian Posted January 18, 2009 Posted January 18, 2009 Format -> Options -> MEP Display Control. Playing around with these options should resolve the issue. Quote
GolfBum Posted January 20, 2009 Posted January 20, 2009 Another thing you can do is >right click >edit object display ....then click the little box in the right hand corner and turn off hidden lines.........this will apply only to the object selected instead of the hole drawing..... Quote
