Bruceybee Posted December 5, 2017 Posted December 5, 2017 Hi forum, I have got as far as obtaining cut/fill values in a column using excel, adjacent to their relevant point coordinates. Now I want to know how I can import the cut/fill value text from excel into AutoCad 2016 dwg, in their relevant positions. The dwgs and xls files are available for reference, in the google drive using the link below. I want to import the cut/fill value in column F, as text in the as-built dwg. Thanks, Bruceybee, Google drive link: https://drive.google.com/open?id=1hG86NOYKA8JPazYSN5x_Kav-ARk5Ti9B Quote
Vittorio Posted March 5, 2018 Posted March 5, 2018 Google Drive tells me that your file is in the trash bin. Could you re-upload it and probably make an example DWG drawing (with a few objects) of the result you're looking for? Quote
ReMark Posted March 5, 2018 Posted March 5, 2018 Vittorio: The post you are responding to dates back three months. If the OP did not find a solution to his problem by now I doubt you'll see the example drawing anytime soon. Quote
