Steven P Posted December 6, 2017 Posted December 6, 2017 good afternoon, I think the answer is probably no for this, but is it possible to open a text file and scroll down to a certain line of text? For example, I have a text file with project numbers and some details for each (lets call them projects 100, 101, 102, 103 and so on). So the goal would be to have a routine that can open the text file and scroll down to show the details for, say project 150 (or another as chosen by the user). i think you can get a LISP to read the line you want but I want to read it in the actual text file. Quote
Roy_043 Posted December 6, 2017 Posted December 6, 2017 If your text application is Notepad: Look into using the Sendkeys method of the WScript.Shell object. Quote
BIGAL Posted December 7, 2017 Posted December 7, 2017 Whats the problem just read each line and when "project" = 100 stop. (close fname) eg 100,BIGAL,September eg2 100 BIGAL September ; thanks to Lee-mac for this defun ; convert csv to a list ; comma is character 44 ; space is 32 (defun _csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2)))) (list str) ) ) Quote
Steven P Posted December 8, 2017 Author Posted December 8, 2017 Thanks. Roy - that looks promising, I haven't had chance to look into this since I asked but that could be what I want. Similarly BigAl, thanks - Useful I think, again I haven't had time yet to look at this, I'll probably have more questions on this when I get 10 minutes free... Quote
Steven P Posted December 15, 2017 Author Posted December 15, 2017 Thanks for the replies.. now as the office empties for Christmas lunch I have had a chance to look at this again. I got so far with Sendkeys and it looks promising, but the one thing I am struggling with is that when the file opens AutoCAD stops the command until I go back into it and then resumes... so ctrl+F (for 'find;) then toggles AutoCAD OSNAP. Right so how do I keep AutoCAD executing the LISP when a text file opens up? So far my quick code is (and with thanks to another Lee Mac peie of genius) (startapp "notepad" "c:\\Users\\SP\\Desktop\\LISPTEST.LSP") (setq sendkeyscommand "^Ffindtext{enter}") ;; ^F = Find ;;Findtext = text to find ;;{enter} = enter (LM:SendKeys sendkeyscommand) ;;^ = ctrl ) ;;Lee Mac Code (defun LM:sendkeys ( keys / wsh ) ;;note can also be used to run a LISP.... (setq wsh (vlax-create-object "wscript.shell")) (vl-catch-all-apply 'vlax-invoke (list wsh 'sendkeys keys)) (vlax-release-object wsh) (princ) ) Quote
ronjonp Posted December 15, 2017 Posted December 15, 2017 What are you doing once you find this line? Quote
Steven P Posted December 16, 2017 Author Posted December 16, 2017 Hi RonJon, I was just wanting to view the line / text in the file. Indtead of just opening the text file and manually scrolling down to the part I want I was wondering if a routine can do both Quote
BIGAL Posted December 16, 2017 Posted December 16, 2017 If you go back to my post and just simply read a text file look for some variable = value and stop then just use ALERT. Copy this to command line (Alert "this is a test") ; crude version ; (setq lineread etc.... from file (if (= val variable) (alert (strcat "Found the line \n" lineread)) ) Quote
Steven P Posted December 16, 2017 Author Posted December 16, 2017 Hi BigAl, Many thanks for your suggestion though its not quite what I am looking for. Very useful if I want to read something from a text file and use it within a LISP routine later - and I'll make a note of it because I think it will be usefull another time. I was wondering if it was possible to open the text file, perform a 'find' within the text file and rather than grab the text to use in AutoCAD but to view the text in the file via notepad (or similar). Quote
Roy_043 Posted December 17, 2017 Posted December 17, 2017 The code below works for Notepad++ and Notepad (remove "++" twice). Note 1: In some languages the title bar name of Notepad is not "Notepad". Note 2: You have to dial in the delay. ; (NotepadFind "C:\\Downloads\\test 123.txt" "findtext" 300) (defun NotepadFind (fnm str delay / obj) (vl-catch-all-apply (function (lambda () (setq obj (vlax-get-or-create-object "WScript.Shell")) (vlax-invoke obj 'Run (strcat "Notepad++.exe \"" fnm "\"")) (setvar 'cmdecho 0) (command "_.delay" delay) ; Milliseconds. For BricsCAD users: (sleep delay) does not work. (setvar 'cmdecho 1) (vlax-invoke obj 'AppActivate "Notepad++") ; Title bar name of application. (vlax-invoke obj 'SendKeys (strcat "^f" str "{ENTER}{ESC}")) ) ) ) (if obj (vlax-release-object obj)) ) Quote
Steven P Posted December 18, 2017 Author Posted December 18, 2017 Thanks!! That loos like it works exactly as I want it to, many thanks - and I was just expecting a 'no it can't be done'. Right, now to break it and work out and learn from what you did (though maybe do that between Christmas and new year when its very quiet). Quote
