Siberian Posted January 15, 2009 Posted January 15, 2009 I was in the Piping workspace drawing a pipe in the 'Waste piping' system. When I was done I noticed that the pipe had been placed on the layer named 'H-MedicalGas-G' which can't possibly be right...? Quote
Hedgehog Posted January 16, 2009 Posted January 16, 2009 Waste Piping system... is this an add-on CAD package? Quote
iain9876 Posted January 16, 2009 Posted January 16, 2009 I was in the Piping workspace drawing a pipe in the 'Waste piping' system. When I was done I noticed that the pipe had been placed on the layer named 'H-MedicalGas-G' which can't possibly be right...? wastepipe on the wrong layer... Sounds like a job for the plumber....! yea I reccomend you call one immediately! Quote
Hedgehog Posted January 16, 2009 Posted January 16, 2009 wastepipe on the wrong layer...Sounds like a job for the plumber....! yea I reccomend you call one immediately! Duh!... this is CAD... if it was blocked you'd just explode it... no need for a plumber! Quote
Siberian Posted January 16, 2009 Author Posted January 16, 2009 Waste Piping system... is this an add-on CAD package? No, it's way down in the system-list in the Piping workspace. Quote
Hedgehog Posted January 16, 2009 Posted January 16, 2009 ABS? MEP?... or ordinary AutoCAD? /edit... ah sorry... this is the MEP forum... I was looking at youir profile which just says AutoCAD 2009 ... sorry... while I have MEP installed we don't use it any more... shifted over to CadDuct. Quote
LifeoRiley0 Posted January 19, 2009 Posted January 19, 2009 Siberian, I don't see waste piping on mine but can't you layer isolate then change the system in the properties box? Quote
GolfBum Posted January 21, 2009 Posted January 21, 2009 Try changing the system....In 09 select a piece of pipe (or Fitting) in the a run of pipe ...Right click and go to modify run....Look on the right side of the drop down boxes for system on the left you will see your current system......change the system in the drop down box and you should be on the correct layer.....If not then it is a layer key issue Quote
