I get the following text in the AutoCAD text window when I try to run a lisp that replaces strings of text. The LISP is locate in the first comment
UNPAIRING24
((-1 . ) (0 . "TEXT") (330 . ) (5 . "71") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "GREEN-012") (100 . "AcDbText") (10 -26.25 23.3125 0.0) (40 . 0.125) (1 . "2LT-5021-PR#1") (50 . 0.0) (41 . 0.8) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 0) (11 -26.25 23.375 0.0) (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 2))
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command:
UNPAIRING24
Command:
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command:
Automatic save to C:\Users\z018780\appdata\local\temp\new block_1_1_3403.sv$ ...
Command:
Command:
(defun c:UNPAIRING24 ()
(setq ss_blk (ssget "x" '((0 . "INSERT") (66 . 1))))
(if ss_blk
(setq lst_blk (sel2lst ss_blk))
(foreach en_blk lst_blk
(setq lst_atts (att2lst en_blk))
(setq str_line "")
(foreach en_atts lst_atts
(setq str_line (getval 1 en_atts))
(if (not (wcmatch str_line "*/*/*"))
(setq str_line (strchg str_line " PR#24" "-1/PR"))
(setq str_line (strchg str_line " PR#23" "-1/PR"))
(setq str_line (strchg str_line " PR#22" "-1/PR"))
(setq str_line (strchg str_line " PR#21" "-1/PR"))
(setq str_line (strchg str_line " PR#20" "-1/PR"))
(setq str_line (strchg str_line " PR#19" "-1/PR"))
(setq str_line (strchg str_line " PR#18" "-1/PR"))
(setq str_line (strchg str_line " PR#17" "-1/PR"))
(setq str_line (strchg str_line " PR#16" "-1/PR"))
(setq str_line (strchg str_line " PR#15" "-1/PR"))
(setq str_line (strchg str_line " PR#14" "-1/PR"))
(setq str_line (strchg str_line " PR#13" "-1/PR"))
(setq str_line (strchg str_line " PR#12" "-1/PR"))
(setq str_line (strchg str_line " PR#11" "-1/PR"))
(setq str_line (strchg str_line " PR#10" "-1/PR"))
(setq str_line (strchg str_line " PR#9" "-1/PR"))
(setq str_line (strchg str_line " PR#8" "-1/PR"))
(setq str_line (strchg str_line " PR#7" "-1/PR"))
(setq str_line (strchg str_line " PR#6" "-1/PR"))
(setq str_line (strchg str_line " PR#5" "-1/PR"))
(setq str_line (strchg str_line " PR#4" "-1/PR"))
(setq str_line (strchg str_line " PR#3" "-1/PR"))
(setq str_line (strchg str_line " PR#2" "-1/PR"))
(setq str_line (strchg str_line " PR#1" "-1/PR"))
(setval 1 str_line en_atts)
(setq ss_txtlines (ssget "x" '((0 . "TEXT"))))
(if ss_txtlines
(setq lst_txtlines (sel2lst ss_txtlines))
(setq str_line "")
(foreach en_txtlines lst_txtlines
(setq str_line (getval 1 en_txtlines))
(setval 1 str_line en_txtlines)
I don't speak LISP or any programming language
NEVER MIND. It was a mistake in the text to be changed.
