Did the ddnumb.lsp work? I used it a lot in my work until I upgraded from 2016 to 2017. So I don't even use 2017. Is there a ddnumb.lsp for 2017?
I used ddnumb.lsp for years, and it saves me lots of time. But it quit working in 2017, so I only use 2016. Has this been updated?
cadalyst might be the source.
I see there is a dcl file as well as the lsp file. Has anything changed with the pathing between your versions of AutoCad?
I see that you are double posting. You can sort out any answers in both your threads.
That lisp isn't version dependent. Should work fine for 2017.
I think you should change read only folder of Program Files if you are using Windows 10 to full control - read-write... There you should have installed your ACAD, and if Support folder under ACAD is with full control, you should be able to use this my mod... :
                                       ;DDNUMB.LSP for release 15
                                       ;Auto numbers text strings.
                                       ;Written by: S. Restmeyer 3/01
;;;----------------------ERROR FUNCTION----------------------------
(DEFUN ERR (S)                          ;if an error (such as CTRL-C)
                                       ;occurs while this command is active...
 (if (not (member s '("console break" "Function cancelled")))
   (princ (strcat "\nError: " s))
 (command "_.UNDO" "_E")               ;end any outstanding UNDO group
 (setvar "cmdecho" cmd)                ;restore saved mode
 (setq *error* olderr)
;;;---------------------- MAIN PROGRAM ----------------------------
(defun C:DDNUMB (/ CMD dcl_id1 olderr fn fname)
 (vl-load-com)
 (setq olderr  *error*
       *error* err
 (SETQ CMD (GETVAR "CMDECHO"))
 (command "_.UNDO" "_G")
 (setvar "cmdecho" 0)
 (defun set_replace ()
   (cond
     ((= (get_tile "do_replace") "0")
      (set_tile "sort_type" "0")
      (mode_tile "sort_type" 1)
      (set_tile "start_no" " ")
      (mode_tile "start_no" 1)
      (set_tile "txt_inc" " ")
      (mode_tile "txt_inc" 1)
   (cond
     ((= (get_tile "do_replace") "1")
      (mode_tile "sort_type" 0)
      (mode_tile "start_no" 0)
      (mode_tile "txt_inc" 0)
      (if sort_type
        (set_tile "sort_type" sort_type)
      (if txt_inc
        (set_tile "txt_inc" (rtos txt_inc 2 0))
        (set_tile "txt_inc" "1")
      (if start_no
        (set_tile "start_no" (rtos start_no 2 0))
        (set_tile "start_no" "1")
 (defun my_help ()
   (setq file_name (findfile "autonumb.pdf"))
   (startapp "acrobat.exe" (strcat "\"" file_name "\""))
   (prompt "\nFile \"autonumb.pdf\" not found... Can't initialize \"acrobat.exe\" to view help info...")
 (defun get_data ()
   (setq suffix (get_tile "suffix"))
   (setq prefix (get_tile "prefix"))
   (setq start_no (atoi (get_tile "start_no")))
   (setq txt_inc (atoi (get_tile "txt_inc")))
   (setq sort_type (get_tile "sort_type"))
   (setq do_replace (get_tile "do_replace"))
;;;-----------THIS SECTION RETRIEVES USER INPUT INFORMATION------------
 (setq fn (open (setq fname (strcat (vla-get-path (vlax-get-acad-object)) "\\Support\\autonumb.dcl")) "w"))
 (write-line "//----------------------------------------------------------------------------" fn)
 (write-line "// " fn)
 (write-line "// Corresponding dialogue for DDNUMB.LSP" fn)
 (write-line "" fn)
 (write-line "//dcl_settings : default_dcl_settings { audit_level = 3; }" fn)
 (write-line "" fn)
 (write-line "" fn)
 (write-line "ddstart : dialog {" fn)
 (write-line "     label = \"Auto Number\";" fn)
 (write-line "        initial_focus = \"prefix\";" fn)
 (write-line "                : row {" fn)
 (write-line "                : boxed_column {" fn)
 (write-line "                        fixed_width = true;" fn)
 (write-line "                        label = \"&Prefix\";" fn)
 (write-line "                                : edit_box {" fn)
 (write-line "                                        key = \"prefix\";" fn)
 (write-line "                                        mnemonic = \"P\";" fn)
 (write-line "                                           }" fn)
 (write-line "                        label = \"Start &No\";" fn)
 (write-line "                                        key = \"start_no\";" fn)
 (write-line "                                        mnemonic = \"N\";" fn)
 (write-line "                        label = \"&Suffix\";" fn)
 (write-line "                                        key = \"suffix\";" fn)
 (write-line "                                        mnemonic = \"S\";" fn)
 (write-line "                        label = \"&Increment\";" fn)
 (write-line "                                        key = \"txt_inc\";" fn)
 (write-line "                                        mnemonic = \"I\";" fn)
 (write-line "                        label = \"Sort &By\";" fn)
 (write-line "                                : popup_list {" fn)
 (write-line "                                        key = \"sort_type\";" fn)
 (write-line "                                        width = 13;" fn)
 (write-line "                : toggle {" fn)
 (write-line "                        label = \"Replace\";" fn)
 (write-line "                        key = \"do_replace\";" fn)
 (write-line "                        value = 1;" fn)
 (write-line "                spacer_1;" fn)
 (write-line "        ok_cancel;" fn)
 (write-line "                        : button {" fn)
 (write-line "                                key = \"numb_hlp\";" fn)
 (write-line "                                label = \"Help\";" fn)
 (write-line "                                mnemonic = \"H\";" fn)
 (close fn)
 (setq dcl_id1 (load_dialog "autonumb.dcl"))
 (if (not (new_dialog "ddstart" dcl_id1))
   (exit)
 (setq sort_list '("Selection"       "Top-Bottom"
                   "Left-Right"      "Bottom-Top"
                   "Right-Left"
 (start_list "sort_type")
 (mapcar 'add_list sort_list)
 (end_list)
 (if sort_type
 (if prefix
   (set_tile "prefix" prefix)
 (if suffix
   (set_tile "suffix" suffix)
 (if start_no
 (if txt_inc
 (action_tile "do_replace" "(set_replace)")
 (action_tile "numb_hlp" "(my_help)")
 (action_tile
   "accept"
   "(setq start_ok T)(get_data)(done_dialog 1)"
 (action_tile "cancel" "(setq start_ok nil)(done_dialog 0)")
 (start_dialog)
 (unload_dialog dcl_id1)
 (if (findfile fname)
   (vl-file-delete fname)
;;;---------------THIS SECTION MODIFIES SELECTED TEXT-----------------
 (defun get_txt (/ sset sset1 sset2 sset3 test num llen temp old)
   (setq sset (ssget '((0 . "TEXT"))))
   (setq num 0)
   (if (= do_replace "1")
       (cond
         ((= sort_type "0")
          (while (< num (sslength sset))
            (setq temp (entget (ssname sset num)))
            (setq old (assoc 1 temp))
            (setq
              new (cons 1 (strcat prefix (rtos start_no 2 0) suffix))
            (setq temp (subst new old temp))
            (entmod temp)
            (setq start_no (+ start_no txt_inc))
            (setq num (+ num 1))
         ((= sort_type "1")
          (setq temp (caddr (assoc 10 (entget (ssname sset num)))))
          (setq sset1 (list temp))
            (setq sset1 (append sset1 (list temp)))
          (setq sset2 (list ""))
          (while (< (- (length sset2) 1) (sslength sset))
            (setq temp (apply 'max sset1))
            (setq sset2 (append sset2 (list temp)))
            (setq sset3 (list ""))
            (setq num (- (length sset1) 1))
            (while (> num -1)
              (setq test (nth num sset1))
              (if (not (member test sset2))
                (setq sset3 (append sset3 (list test)))
              (setq num (- num 1))
            (setq sset1 (cdr sset3))
          (setq sset2 (cdr sset2))
          (setq llen 0)
          (while (< llen (length sset2))
            (setq test (nth llen sset2))
            (setq num 0)
            (while
              (not
                (= (caddr (assoc 10 (entget (ssname sset num)))) test)
            (setq
            (entmod temp)
            (setq llen (+ llen 1))
         ((= sort_type "2")
          (setq temp (cadr (assoc 10 (entget (ssname sset num)))))
            (while (> num -1)
          (setq llen (- (length sset2) 1))
          (while (> llen -1)
            (setq num 0)
            (while
              (not (= (cadr (assoc 10 (entget (ssname sset num)))) test)
            (setq
            (entmod temp)
            (setq llen (- llen 1))
         ((= sort_type "3")
            (while (> num -1)
          (while (> llen -1)
            (setq num 0)
            (while
              (not
            (setq
            (entmod temp)
         ((= sort_type "4")
            (while (> num -1)
          (setq llen 0)
            (setq num 0)
            (while
            (setq
            (entmod temp)
       (setq start_no nil)
       (setq txt_inc nil)
         (setq new (cons 1 (strcat prefix (cdr old) suffix)))
         (entmod temp)
 (if start_ok
   (get_txt)
HTH., M.R.
Edited by marko_ribar
I moved the post from the older thread you resurrected to this thread. Please don't double post.
I know nothing about code. In 2016, I go to TOOLS, LOAD APPLICATION, and pick autonum.lsp. It is stored in the SUPPORT file. I clilck LOAD. Then I type ddnumb as the command. Works great.
In 2017, I load the routine and type ddnumb. I get an error -
Error: quit / exit abort
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
I added a semicolon in front of
to comment it out on line 13 of marko_ribar's code above and it worked fine in 2018. It doesn't work on Mtext like the Express Tool TCOUNT though.
