Maxelkat Posted January 4, 2018 Posted January 4, 2018 This is probably a very easy one for someone to answer. I've recently moved from AutoCAD 2006 to AutoCAD 2018 and am learning all of the changes. One thing that doesn't work is a button I have for changing some text, it falls down when it tries to load the lisp file. I have saved the lisp file in the support folder and ensured that location appears in the support file search path, but when it tries the script inside the button it returns an error message: Command: (load "chtext") ; error: bad argument type: stringp nil Any ideas? Thanks in advance Quote
ronjonp Posted January 4, 2018 Posted January 4, 2018 That's quite the leap in versions! it would be easiest to debug if you post your code. Quote
Maxelkat Posted January 4, 2018 Author Posted January 4, 2018 (edited) ;;; CHTEXT.lsp - change text ;;; ;;; Copyright 1997 by Autodesk, Inc. ;;; ;;; Permission to use, copy, modify, and distribute this software ;;; for any purpose and without fee is hereby granted, provided ;;; that the above copyright notice appears in all copies and ;;; that both that copyright notice and the limited warranty and ;;; restricted rights notice below appear in all supporting ;;; documentation. ;;; ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC. ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE ;;; UNINTERRUPTED OR ERROR FREE. ;;; ;;; Use, duplication, or disclosure by the U.S. Government is subject to ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii) ;;; (Rights in Technical Data and Computer Software), as applicable. ;;; ;;;--------------------------------------------------------------------------; ;;; DESCRIPTION ;;; This is a "text processor" which operates in a global manner ;;; on all of the text entities that the user selects; i.e., the ;;; Height, Justification, Location, Rotation, Style, Text, and ;;; Width can all be changed globally or individually, and the ;;; range of values for a given parameter can be listed. ;;; ;;; The command is called with CHT from the command line at which ;;; time the user is asked to select the objects to change. ;;; ;;; Select text to change. ;;; Select objects: ;;; ;;; If nothing is selected the message "ERROR: Nothing selected." ;;; is displayed and the command is terminated. If more than 25 ;;; entities are selected the following message is displayed while ;;; the text entities are sorted out from the non-text entities. ;;; A count of the text entities found is then displayed. ;;; ;;; Verifying the selected entities... ;;; nnn text entities found. ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; ;;; A typical example of the prompts you may encounter follows: ;;; ;;; If you select a single text entity to change and ask to change ;;; the height, the prompt looks like this: ;;; ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; New text height for text entity. <0.08750000>: ;;; ;;; If you select more than one text entity to change and ask to change ;;; the height, the prompt looks like this: ;;; ;;; CHText: Height/Justification/Location/Rotation/Style/Text/Undo/Width: ;;; Individual/List/<New height for all entities>: ;;; ;;; Typing "L" at this prompt returns a prompt showing you the range of ;;; values that you are using for your text. ;;; ;;; Height -- Min: 0.05000000 Max: 0.10000000 Ave: 0.08392857 ;;; ;;; Typing "I" at this prompt puts you in a loop, processing the text ;;; entities you have selected one at a time, and giving the same prompt ;;; you get for a single text entity shown above. ;;; ;;; Pressing ENTER at this point puts you back at the Command: prompt. ;;; Selecting any of the other options allows you to change the text ;;; entities selected. ;;; ;;;---------------------------------------------------------------------------; (defun cht_Main ( / sset opt ssl nsset temp unctr ct_ver sslen style hgt rot txt ent loc loc1 just-idx justp justq orthom cht_ErrorHandler cht_OrgError cht_OrgCmdecho cht_OrgTexteval cht_OrgHighlight) ;; Reset if changed (setq ct_ver "2.00") ;; Internal error handler defined locally (defun cht_ErrorHandler (s) (if (/= s "Function cancelled") (if (= s "quit / exit abort") (princ) (princ (strcat "\nError: " s)) ) ) (eval (read U:E)) ;; Reset original error handler if there (if cht_OrgError (setq *error* cht_OrgError)) (if temp (redraw temp 1)) (ai_undo_off) ;; restore undo state (if cht_OrgCmdecho (setvar "cmdecho" cht_OrgCmdecho)) (if cht_OrgTexteval (setvar "texteval" cht_OrgTexteval)) (if cht_OrgHighlight (setvar "highlight" cht_OrgHighlight)) (princ) ) ;; Set error handler (if *error* (setq cht_OrgError *error* *error* cht_ErrorHandler) (setq *error* cht_ErrorHandler) ) ;; Set undo groups and ends with (eval(read U:G)) or (eval(read U:E)) (setq U:G "(command \"_.undo\" \"_group\")" U:E "(command \"_.undo\" \"_en\")" ) (ai_undo_on) ;; enable undo (setq cht_OrgCmdecho (getvar "cmdecho")) (setq cht_OrgHighlight (getvar "highlight")) (setvar "cmdecho" 0) (princ (strcat "\nChange text, Version " ct_ver ", Copyright © 1997 by Autodesk, Inc.")) (prompt "\nSelect annotation objects to change.") (setq sset (ai_aselect)) (if (null sset) (progn (princ "\nNo objects selected.") (exit) ) ) ;; Validate selection set (setq ssl (sslength sset) nsset (ssadd)) (if (> ssl 25) (princ "\nVerifying selected objects...") ) (while (> ssl 0) (setq temp (ssname sset (setq ssl (1- ssl)))) (if (or (= (cdr (assoc 0 (entget temp))) "TEXT") (= (cdr (assoc 0 (entget temp))) "ATTDEF") (= (cdr (assoc 0 (entget temp))) "MTEXT") ) (ssadd temp nsset) ) ) (setq ssl (sslength nsset) sset nsset unctr 0 ) (print ssl) (princ "annotation objects found.") ;; Main loop (setq opt T) (while (and opt (> ssl 0)) (setq unctr (1+ unctr)) (command "_.UNDO" "_GROUP") (initget "Location Justification Style Height Rotation Width Text Undo") (setq opt (getkword "\nHeight/Justification/Location/Rotation/Style/Text/Undo/Width: ")) (if opt (cond ((= opt "Undo") (cht_Undo) ) ((= opt "Location") (cht_Location) ) ((= opt "Justification") (cht_Justification) ) ((= opt "Style") (cht_Property "Style" "New style name" 7) ) ((= opt "Height") (cht_Property "Height" "New height" 40) ) ((= opt "Rotation") (cht_Property "Rotation" "New rotation angle" 50) ) ((= opt "Width") (cht_Property "Width" "New width factor" 41) ) ((= opt "Text") (cht_Text) ) ) (setq opt nil) ) (command "_.UNDO" "_END") ) ;; Restore (if cht_OrgError (setq *error* cht_OrgError)) (eval (read U:E)) (ai_undo_off) ;; restore undo state (if cht_OrgTexteval (setvar "texteval" cht_OrgTexteval)) (if cht_OrgHighlight (setvar "highlight" cht_OrgHighlight)) (if cht_OrgCmdecho (setvar "cmdecho" cht_OrgCmdecho)) (princ) ) ;;; Undo an entry (defun cht_Undo () (if (> unctr 1) (progn (command "_.UNDO" "_END") (command "_.UNDO" "2") (setq unctr (- unctr 2)) ) (progn (princ "\nNothing to undo. ") (setq unctr (- unctr 1)) ) ) ) ;;; Change the location of an entry (defun cht_Location () (setq sslen (sslength sset) style "" hgt "" rot "" txt "" ) ;;LCA - COMMENT: The CHANGE command has new options. (command "_.CHANGE" sset "" "") (while (> sslen 0) (setq ent (entget(ssname sset (setq sslen (1- sslen)))) opt (list (cadr (assoc 11 ent)) (caddr (assoc 11 ent)) (cadddr (assoc 11 ent))) ) (prompt "\nNew text location: ") (command pause) (if (null loc) (setq loc opt) ) (command style hgt rot txt) ) (command) ) ;;; Change the justification of an entry (defun cht_Justification () (initget "TL TC TR ML MC MR BL BC BR Align Center Fit Left Middle Right ?") (setq sslen (sslength sset)) (setq justp (getkword "\nAlign/Fit/Center/Left/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR/<?>: ")) (cond ((= justp "Left") (setq justp 0 justq 0 just-idx 4) ) ((= justp "Center") (setq justp 1 justq 0 just-idx 5) ) ((= justp "Right") (setq justp 2 justq 0 just-idx 6) ) ((= justp "Align") (setq justp 3 justq 0 just-idx 1) ) ((= justp "Fit") (setq justp 5 justq 0 just-idx 1) ) ((= justp "TL") (setq justp 0 justq 3 just-idx 1) ) ((= justp "TC") (setq justp 1 justq 3 just-idx 2) ) ((= justp "TR") (setq justp 2 justq 3 just-idx 3) ) ((= justp "ML") (setq justp 0 justq 2 just-idx 4) ) ((= justp "Middle") (setq justp 4 justq 0 just-idx 5) ) ((= justp "MC") (setq justp 1 justq 2 just-idx 5) ) ((= justp "MR") (setq justp 2 justq 2 just-idx 6) ) ((= justp "BL") (setq justp 0 justq 1 just-idx 7) ) ((= justp "BC") (setq justp 1 justq 1 just-idx ) ((= justp "BR") (setq justp 2 justq 1 just-idx 9) ) ((= justp "?") (setq justp nil) ) (T (setq justp nil) ) ) (if justp (progn ;; Process them... (while (> sslen 0) (setq ent (entget (ssname sset (setq sslen (1- sslen))))) (cond ((= (cdr (assoc 0 ent)) "MTEXT") (setq ent (subst (cons 71 just-idx) (assoc 71 ent) ent)) ) ((= (cdr (assoc 0 ent)) "TEXT") (setq ent (subst (cons 72 justp) (assoc 72 ent) ent) opt (trans (list (cadr (assoc 11 ent)) (caddr (assoc 11 ent)) (cadddr (assoc 11 ent))) (cdr (assoc -1 ent)) ;; from ECS 1) ;; to current UCS ) (setq ent (subst (cons 73 justq) (assoc 73 ent) ent)) (cond ((or (= justp 3) (= justp 5)) (prompt "\nNew text alignment points: ") (if (= (setq orthom (getvar "orthomode")) 1) (setvar "orthomode" 0) ) (redraw (cdr (assoc -1 ent)) 3) (initget 1) (setq loc (getpoint)) (initget 1) (setq loc1 (getpoint loc)) (redraw (cdr (assoc -1 ent)) 1) (setvar "orthomode" orthom) (setq ent (subst (cons 10 loc) (assoc 10 ent) ent)) (setq ent (subst (cons 11 loc1) (assoc 11 ent) ent)) ) ((or (/= justp 0) (/= justq 0)) (redraw (cdr (assoc -1 ent)) 3) (prompt "\nNew text location: ") (if (= (setq orthom (getvar "orthomode")) 1) (setvar "orthomode" 0) ) (setq loc (getpoint opt)) (setvar "orthomode" orthom) (redraw (cdr (assoc -1 ent)) 1) (if (null loc) (setq loc opt) (setq loc (trans loc 1 (cdr (assoc -1 ent)))) ) (setq ent (subst (cons 11 loc) (assoc 11 ent) ent)) ) ) ) ) (entmod ent) ) ) (progn ;; otherwise list options (textpage) (princ "\nAlignment options:\n") (princ "\t TL TC TR\n") (princ "\t ML MC MR\n") (princ "\t BL BC BR\n") (princ "\t Left Center Right\n") (princ "\tAlign Middle Fit\n") (princ "\nPress ENTER to continue: ") (grread) (princ "\r ") (graphscr) ) ) (command) ) ;;; Change the text of an object (defun cht_Text ( / ans) (setq sslen (sslength sset)) (initget "Globally Individually Retype") (setq ans (getkword "\nFind and replace text. Individually/Retype/<Globally>:")) (setq cht_OrgTexteval (getvar "texteval")) (setvar "texteval" 1) (cond ((= ans "Individually") (progn (initget "Yes No") (setq ans (getkword "\nEdit text in dialog? <Yes>:")) ) (while (> sslen 0) (redraw (setq sn (ssname sset (setq sslen (1- sslen)))) 3) (setq ss (ssadd)) (ssadd (ssname sset sslen) ss) (if (= ans "No") (cht_Edit ss) (command "_.DDEDIT" sn "") ) (redraw sn 1) ) ) ((= ans "Retype") (while (> sslen 0) (setq ent (entget (ssname sset (setq sslen (1- sslen))))) (redraw (cdr (assoc -1 ent)) 3) (prompt (strcat "\nOld text: " (cdr (assoc 1 ent)))) (setq nt (getstring T "\nNew text: ")) (redraw (cdr (assoc -1 ent)) 1) (if (> (strlen nt) 0) (entmod (subst (cons 1 nt) (assoc 1 ent) ent)) ) ) ) (T (cht_Edit sset) ;; Change all ) ) (setvar "texteval" cht_OrgTexteval) ) ;;; The old CHGTEXT command - rudimentary text editor (defun C:CHGTEXT () (cht_Edit nil)) (defun cht_Edit (objs / last_o tot_o ent o_str n_str st s_temp n_slen o_slen si chf chm cont ans class) ;; Select objects if running standalone (if (null objs) (setq objs (ssget)) ) (setq chm 0) (if objs (progn ;; If any objects selected (if (= (type objs) 'ENAME) (progn (setq ent (entget objs)) (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) ) (if (= (sslength objs) 1) (progn (setq ent (entget (ssname objs 0))) (princ (strcat "\nExisting string: " (cdr (assoc 1 ent)))) ) ) ) (setq o_str (getstring "\nMatch string : " t)) (setq o_slen (strlen o_str)) (if (/= o_slen 0) (progn (setq n_str (getstring "\nNew string : " t)) (setq n_slen (strlen n_str)) (setq last_o 0 tot_o (if (= (type objs) 'ENAME) 1 (sslength objs) ) ) ;; For each selected object... (while (< last_o tot_o) (setq class (cdr (assoc 0 (setq ent (entget (ssname objs last_o)))))) (if (or (= "TEXT" class) (= "MTEXT" class) ) (progn (setq chf nil si 1) (setq s_temp (cdr (assoc 1 ent))) (while (= o_slen (strlen (setq st (substr s_temp si o_slen)))) (if (= st o_str) (progn (setq s_temp (strcat (if (> si 1) (substr s_temp 1 (1- si)) "" ) n_str (substr s_temp (+ si o_slen)) ) ) (setq chf t) ;; Found old string (setq si (+ si n_slen)) ) (setq si (1+ si)) ) ) (if chf (progn ;; Substitute new string for old ;; Modify the TEXT entity (entmod (subst (cons 1 s_temp) (assoc 1 ent) ent)) (setq chm (1+ chm)) ) ) ) ) (setq last_o (1+ last_o)) ) ) ;; else go on to the next line... ) ) ) (if (/= (type objs) 'ENAME) ;; Print total lines changed (if (/= (sslength objs) 1) (princ (strcat (rtos chm 2 0) " text lines changed.")) ) ) (terpri) ) ;;; Main procedure for manipulating text entities (defun cht_Property (typ prmpt fld / temp ow nw ent tw sty w hw lw sslen n sn ssl) (if (= (sslength sset) 1) ;; Special case if there is only ;; one entity selected ;; Process one entity. (cht_ProcessOne) ;; Else (progn ;; Set prompt string. (cht_SetPrompt) (if (= nw "List") ;; Process List request. (cht_ProcessList) (if (= nw "Individual") ;; Process Individual request. (cht_ProcessIndividual) (if (= nw "Select") ;; Process Select request. (cht_ProcessSelect) ;; Else (progn (if (= typ "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (if (= (type nw) 'STR) (if (not (tblsearch "style" nw)) (progn (princ (strcat nw ": Style not found. ")) ) (cht_ProcessAll) ) (cht_ProcessAll) ) ) ) ) ) ) ) ) ;;; Change all of the entities in the selection set (defun cht_ProcessAll (/ hl temp) (setq sslen (sslength sset)) (setq hl (getvar "highlight")) (setvar "highlight" 0) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) (setvar "highlight" hl) ) ;;; Change one text entity (defun cht_ProcessOne () (setq temp (ssname sset 0)) (setq ow (cdr (assoc fld (entget temp)))) (if (= opt "Rotation") (setq ow (/ (* ow 180.0) pi)) ) (redraw (cdr (assoc -1 (entget temp))) 3) (initget 0) (if (= opt "Style") (setq nw (getstring (strcat prmpt " <" ow ">: "))) (setq nw (getreal (strcat prmpt " <" (rtos ow 2) ">: "))) ) (if (or (= nw "") (= nw nil)) (setq nw ow) ) (redraw (cdr (assoc -1 (entget temp))) 1) (if (= opt "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (if (= opt "Style") (if (null (tblsearch "style" nw)) (princ (strcat nw ": Style not found. ")) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) ) ) ;;; Set the prompt string (defun cht_SetPrompt () (if (= typ "Style") (progn (initget "Individual List New Select ") (setq nw (getkword (strcat "\nIndividual/List/Select style/<" prmpt " for all text objects" ">: "))) (if (or (= nw "") (= nw nil) (= nw "Enter")) (setq nw (getstring (strcat prmpt " for all text objects" ": "))) ) ) (progn (initget "List Individual" 1) (setq nw (getreal (strcat "\nIndividual/List/<" prmpt " for all text objects" ">: "))) ) ) ) ;;; Process List request (defun cht_ProcessList () (setq unctr (1- unctr)) (setq sslen (sslength sset)) (setq tw 0) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (if (= typ "Style") (progn (if (= tw 0) (setq tw (list (cdr (assoc fld (entget temp))))) (progn (setq sty (cdr (assoc fld (entget temp)))) (if (not (member sty tw)) (setq tw (append tw (list sty))) ) ) ) ) (progn (setq tw (+ tw (setq w (cdr (assoc fld (entget temp)))))) (if (= (sslength sset) (1+ sslen)) (setq lw w hw w)) (if (< hw w) (setq hw w)) (if (> lw w) (setq lw w)) ) ) ) (if (= typ "Rotation") (setq tw (* (/ tw pi) 180.0) lw (* (/ lw pi) 180.0) hw (* (/ hw pi) 180.0)) ) (if (= typ "Style") (progn (princ (strcat "\n" typ "(s) -- ")) (princ tw) ) (princ (strcat "\n" typ " -- Min: " (rtos lw 2) "\t Max: " (rtos hw 2) "\t Avg: " (rtos (/ tw (sslength sset)) 2) ) ) ) ) ;;; Process Individual request (defun cht_ProcessIndividual () (setq sslen (sslength sset)) (while (> sslen 0) (setq temp (ssname sset (setq sslen (1- sslen)))) (setq ow (cdr (assoc fld (entget temp)))) (if (= typ "Rotation") (setq ow (/ (* ow 180.0) pi)) ) (initget 0) (redraw (cdr (assoc -1 (entget temp))) 3) (if (= typ "Style") (progn (setq nw (getstring (strcat "\n" prmpt " <" ow ">: "))) ) (progn (setq nw (getreal (strcat "\n" prmpt " <" (rtos ow 2) ">: "))) ) ) (if (or (= nw "") (= nw nil)) (setq nw ow) ) (if (= typ "Rotation") (setq nw (* (/ nw 180.0) pi)) ) (entmod (subst (cons fld nw) (assoc fld (setq ent (entget temp))) ent ) ) (redraw (cdr (assoc -1 (entget temp))) 1) ) ) ;;; Process the Select option (defun cht_ProcessSelect () (princ "\nSearch for which Style name? <*>: ") (setq sn (xstrcase (getstring)) n -1 nsset (ssadd) ssl (1- (sslength sset)) ) (if (or (= sn "*") (null sn) (= sn "")) (setq nsset sset sn "*") (while (and sn (< n ssl)) (setq temp (ssname sset (setq n (1+ n)))) (if (= (cdr (assoc 7 (entget temp))) sn) (ssadd temp nsset) ) ) ) (princ (strcat "\nStyle: " sn)) (print (setq ssl (sslength nsset))) (princ "objects found.") ) ;;; Check to see if AI_UTILS is loaded, If not, try to find it, ;;; and then try to load it. If it can't be found or can't be ;;; loaded, then abort the loading of this file immediately. (cond ((and ai_dcl (listp ai_dcl))) ; it's already loaded. ((not (findfile "ai_utils.lsp")) ; find it (ai_abort "CHT" nil) ) ((eq "failed" (load "ai_utils" "failed")) ; load it (ai_abort "CHT" nil) ) ) ;;; If we get this far, then AI_UTILS.LSP is loaded and it can ;;; be assumed that all functions defined therein are available. ;;; Next, check to see if ACADAPP.EXP has been xloaded, and abort ;;; if the file can't be found or xloaded. Note that AI_ACADAPP ;;; does not abort the running application itself (so that it can ;;; also be called from within the command without also stopping ;;; an AutoCAD command currently in progress). (if (not (ai_acadapp)) (ai_abort "CHT" nil)) ;;; The C: function definition (defun c:cht () (cht_Main)) (princ "\n\tCHT command loaded.") (princ) Edited January 5, 2018 by Maxelkat Quote
Maxelkat Posted January 4, 2018 Author Posted January 4, 2018 Alternatively is there a way to use the FIND command on the command line, as that should solve my text replacement requirements? Quote
ronjonp Posted January 4, 2018 Posted January 4, 2018 Sorry .. don't have time to debug Autodesk's Express Tools stuff... this just looks like it changes text properties? If so, consider selecting text then using the properties palette to do the same. (defun c:foo (/ s) (if (setq s (ssget ":L" '((0 . "text")))) (progn (sssetfirst nil s) (vl-cmdf "_.properties")) ) (princ) ) Quote
Maxelkat Posted January 4, 2018 Author Posted January 4, 2018 That's fine I wouldn't expect you too. I assumed the problem was with how I was trying to load the lisp rather than with the lisp itself, otherwise I wouldn't have asked. Thanks for the script, I'll try it out. Quote
ronjonp Posted January 4, 2018 Posted January 4, 2018 Maybe try loading "CHT" although if you type expresstools in the command line I thought all this stuff was autoloaded? ;;; The C: function definition(defun c:cht () (cht_Main)) (princ "\n\tCHT command loaded.") (princ) Quote
SLW210 Posted January 4, 2018 Posted January 4, 2018 Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[NOPARSE] Your Code Here[/NOPARSE] = Your Code Here Quote
BIGAL Posted January 5, 2018 Posted January 5, 2018 Your load is correct syntax, pasted code to vlide and it reported an error in your lisp code so its loading but failing. Unfortunately need to check the code. You have a confict with another command as per Ronjonp Found it (defun c:chtt () (cht_Main)) works, dont use CHT or CT or CTX Quote
