Deleting Solid hatching within blocks according to block name
Good morning all. I've found this routine that ALMOST does what i need it to do. Basically, I need this routine to only run on blocks that have a suffix of "-NI" (ex. XXX-##-XX-#-NI) at the end of the block name. Does anyone have any idea how to do this? I'm not great working with vla stuff. Anything helps! Thanks!!
EDIT: just FYI these will be dynamic blocks, if that makes any difference.
(defun c:Test (/ doc)
 (vlax-for bks (vla-get-blocks (setq
                     doc (vla-get-ActiveDocument (vlax-get-acad-object))
   (if (and (eq :vlax-false (vla-get-islayout bks))
            (eq :vlax-false (vla-get-isXref bks))
     (vlax-for obj bks
       (if (and (wcmatch (vla-get-objectname obj)
                         "AcDbHatch"
                (vlax-write-enabled-p obj)
         (vla-delete obj)
 (vla-regen doc AcAllViewports)
)(vl-load-com)
Hi,
Its a good manner to reference the codes to the link where you got them from as long as you are not the one who wrote them. Right?
(if (and
(wcmatch (vla-get-name bks) "*-NI")
This is perfect, thank you!
I've honestly had this one sitting around for a while after using it for another application a while back! I'm not too sure where it came from! Very appreciative to whoever did write it though! Works great, and thank you very much for the extra line!
