dilan Posted January 9, 2018 Posted January 9, 2018 Hello everybody! On my computer in the Temp folder, I have .txt files. I know their names and positions, how can I delete them using lsp? I thought that I myself could write a program, but later I understood that I can not manage. I started with that first need to get a username: (setq username (getenv "username")) But on this and stopped.... I do not have enough knowledge to finish it (( I decided to apply to specialists Quote
BIGAL Posted January 9, 2018 Posted January 9, 2018 A batch file is easier and can be ran outside Autocad. Save this to c:\ as deltext.bat just type c:\deltext in the square bottom left as a command in windows. Yes you can run inside Autocad as well. c: cd \temp del *.txt If their part of a lisp program and your writing say temporary files then use (vl-file-delete filename) but its one file at a time. Quote
dilan Posted January 9, 2018 Author Posted January 9, 2018 A batch file is easier and can be ran outside Autocad. Save this to c:\ as deltext.bat just type c:\deltext in the square bottom left as a command in windows. Yes you can run inside Autocad as well. c: cd \temp del *.txt If their part of a lisp program and your writing say temporary files then use (vl-file-delete filename) but its one file at a time. Thank you BIGAL I will try to use the second option Quote
rlx Posted January 9, 2018 Posted January 9, 2018 (edited) Welcome on Cadtutor Dilan quickly copied and pasted something together , just for fun and barely tested. But for file operations beautiful tools like Total Commander etc. exists. ; [url]http://www.cadtutor.net/forum/showthread.php?102517-Delete-files-directory-or-folder-on-your-computer-using-Lsp[/url] ; written by RLX for Dilan 9 jan 2018 (defun c:Delete_Dilan ( / folder extension file file-list ) (vl-load-com) (if (and (setq extension "*.txt" folder (GetFolder "Select folder with txt files")) (vl-consp (setq file-list (vl-directory-files folder extension 1))) (vl-consp (setq file-list (Tokkie folder extension file-list file-list))) (vl-consp (setq file-list (mapcar '(lambda (x)(strcat folder "\\" x)) file-list)))) (foreach file file-list (vl-file-delete file)) ) (princ) ) ; test (setq fldr (GetFolder "Who , what , Where?")) (defun GetFolder ( msg / sh objFolder objParentFolder strPath) (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" )) (setq objFolder (vlax-invoke sh 'BrowseForFolder 0 msg 0 "")) (if objFolder (and (setq strTitle (vlax-get objFolder "Title")) (setq objParentFolder (vlax-get objFolder 'ParentFolder)) (setq strPath (vlax-get (vlax-invoke objParentFolder "Parsename" strTitle) "Path")) (vlax-release-object objParentFolder) (vlax-release-object objFolder)) (vlax-release-object sh) ) strPath ) (defun pimp_list ( %lst / i imax slim) ; stringlimit (emperical), uppercase is bigger , but so are many M's or W's (if (= #RlxBatch-ShowUpperCaseNames "1") (setq slim 82)(setq slim 95)) (if (or (void RlxBatch-UseTempProjectList) (= RlxBatch-UseTempProjectList "0")) (progn (setq i 0 imax (strlen (itoa (length %lst)))) (mapcar '(lambda (x) (setq i (1+ i)) (strcat (fixitoa i imax) " - " (limitstring x slim))) %lst) ) ; this option retains number of position in (main) project list for item in sub project list (progn (setq imax (strlen (itoa (length RlxBatch-ProjectList)))) (mapcar '(lambda (x) (strcat (fixitoa (1+ (vl-position (strcase x t) RlxBatch-ProjectList)) imax) " - " (limitstring x slim))) %lst ) ) ) ) ; s = string , n = max string length (defun limitstring ( s n / l) (setq l (strlen s)) (if (> l n) (strcat (substr s 1 (- (/ n 2) 7 )) " . . . " (substr s (- l (/ n 2)))) (strcat s ""))) ;check if item is nil of empty string (5 spaces deep) (defun void (x) (if (member x (list "" " " " " " " " " " " nil '())) t nil)) ; make sure itoa has fixed length , i.e. (fixitoa 1 3) -> "001" (defun fixitoa ( #i #n / s ) (setq s (itoa #i))(while (> #n (strlen s))(setq s (strcat "0" s))) s) ;--- Tokkie ------------------------------------------------------Tokkie ------------------------------------------------------- Tokkie --- ; alternative for listbox multiple selection, a lot of trouble (and not necessarily better) , just different ; $txt1 & 2 = header text 1 & 2 , %lst% list of strings, %plist = pre-selected list of strings (if any) ; (Tokkie "Block1" "Attributes for visibility2" '("a1" "a2" "a3") '("a2")) ; this means toggle for "a1" & "a3" are "0" (off) and "a2" is on ("1") ; if previous list is empty all toggles will have default "0" (this differs from my original smartlist routines) ; also different is pretty-list , designed to limit string length of members in the list (defun Tokkie ( $txt1 $txt2 %lst %plist / err fn fp dcl nof-tog cur-tog pretty-list tokkie-list slider-index return) (Tokkie_Init) (Tokkie_Dialog) (Tokkie_Exit) (terpri) (reverse return) ) (defun Tokkie_Init () ;(setq err *error* *error* Tokkie_err) (cond ((not (setq fn (vl-filename-mktemp "Tokkie.dcl")))) ((not (setq fp (open fn "w")))) ((null %lst)) ; tokkie-list keeps toggle value (default "1") for each member in %lst (t (setq nof-tog (length %lst) pretty-list (pimp_list %lst))) ) ; tokkie list holds default for toggles - (chr 49) = "1" , (chr 48) = "0" (if (and (not (null %lst)) (not (null %plist))) ; if item is found in both argument lists , set toggle on ("1") else off ("0") (setq tokkie-list (mapcar '(lambda (x)(if (member x %plist)(chr 49)(chr 48))) %lst)) ; if empty or no preset list was provided all tokkies are off (setq tokkie-list (mapcar '(lambda (x) (chr 48)) %lst))) (if (null %lst) (progn (alert "Nothing to show")(Tokkie_Exit)) (progn (Tokkie_write_header) (if (<= nof-tog 10)(Tokkie_write_body1 pretty-list)(Tokkie_write_body2 pretty-list)) (Tokkie_write_footer) ) ) (if fp (close fp))(gc) (setq slider-index 0) ) (defun Tokkie_err (s) (princ s)(Tokkie_Exit)(princ)) (defun Tokkie_Exit () ;|(setq *error* err)|; (if fp (close fp)) (if dcl (unload_dialog dcl))(if (and fn (findfile fn))(vl-file-delete fn))) (defun Tokkie_write_header () (write-line (strcat "Tokkie:dialog{label=\"Tokkie - Rlx(2017)\";spacer;spacer;" ":text_part {key=\"txt1\";width=100;fixed_width=true;}" ":text_part{key=\"txt2\";width=100;fixed_width=true;}spacer;") fp)) (defun Tokkie_write_body1 ( %l / i ) (write-line ":boxed_column{" fp) (setq i 0) (mapcar '(lambda (x) (write-line (strcat ":row{spacer;:toggle{key=\"tg" (itoa i) "\";width=2;fixed_width=true;}" ":text_part{key=\"tp" (itoa i) "\";label=\"" x "\";width=100;fixed_width=true;}}") fp) (setq i (1+ i))) %l ) (repeat (- 10 i)(write-line ":row{height=1.5;}" fp)) (write-line "}spacer;" fp) ) (defun Tokkie_write_body2 ( %l / i ) (write-line ":boxed_row {:column{" fp) (setq i 0) (repeat 10 (write-line (strcat ":row { spacer; :toggle { key =\"tg" (itoa i) "\";width=2;fixed_width=true;}" ":text_part{key=\"tp" (itoa i) "\";label=\"" (nth i %l) "\";width=100;fixed_width=true;}}") fp) (setq i (1+ i)) ) (write-line (strcat "}:column{:slider{key=\"sldr\";layout=vertical;min_value="(itoa (- 0 nof-tog)) ";max_value=0" ";small_increment=1;big_increment=10;value=0;}}}spacer;") fp) ) (defun Tokkie_write_footer () (write-line (strcat "spacer;" ": row {: button{label=\"Select All\";key=\"all\";}:button{label=\"Select None\";key=\"none\";}}" "spacer;ok_cancel;}") fp)) (defun Tokkie_Dialog ( / n drv inp) (if (and (setq n 0 dcl (load_dialog fn)) (new_dialog "Tokkie" dcl)) (progn (Tokkie_DialogUpdate) (Tokkie_DialogActions) (setq drv (start_dialog)) (if (= drv 1) (mapcar '(lambda (x y) (if (= x "1")(setq return (cons y return)))) tokkie-list %lst) (setq return nil)) ) ) ) (defun Tokkie_DialogUpdate ( / i ) (if (= (type $txt1) 'STR)(set_tile "txt1" $txt1)) (if (= (type $txt2) 'STR)(set_tile "txt2" $txt2)) (set_tile "sldr" (itoa slider-index)) (update_tokkies) ) (defun Tokkie_DialogActions () (repeat 10 (action_tile (strcat "tg" (itoa n)) (strcat "(toggle_me $value " (itoa n) ")" ))(setq n (1+ n))) (action_tile "sldr" "(update_slider $value)") (action_tile "all" "(Tokkie_SelectAll)") (action_tile "none" "(Tokkie_SelectNone)") (action_tile "ok" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") ) (defun update_slider ( #i ) (setq slider-index (atoi #i)) (Tokkie_DialogUpdate)) (defun update_tokkies (/ tokkie-index tokkie-name i) ;max number of toggles in dialog is 10 (if (> (abs slider-index) (- nof-tog 10)) (setq tokkie-index (- nof-tog 10))(setq tokkie-index (abs slider-index))) (if (< tokkie-index 0)(setq tokkie-index 0)) (setq i 0) (while (and (< i 10) (setq tokkie-name (nth tokkie-index pretty-list))) (set_tile (strcat "tp" (itoa i)) tokkie-name) (set_tile (strcat "tg" (itoa i)) (nth tokkie-index tokkie-list)) (setq i (1+ i) tokkie-index (1+ tokkie-index)) ) ) (defun toggle_me ( $v #i / idx ) (if (> (abs slider-index) (- nof-tog 10))(setq idx (- nof-tog 10))(setq idx (abs slider-index))) (setq tokkie-list (nthSubst (+ #i (if (< idx 0) 0 idx)) $v tokkie-list)) ) (defun Tokkie_SelectAll ();reset all toggles to "1" ;(setq tokkie-list (mapcar '(lambda (x) (chr 49)) %lst))(Tokkie_DialogUpdate)) (setq tokkie-list (mapcar '(lambda (x) (chr 49)) pretty-list))(Tokkie_DialogUpdate)) (defun Tokkie_SelectNone ();reset all toggles to "0" ;(setq tokkie-list (mapcar '(lambda (x) (chr 48)) %lst))(Tokkie_DialogUpdate)) (setq tokkie-list (mapcar '(lambda (x) (chr 48)) pretty-list))(Tokkie_DialogUpdate)) (defun nthSubst (i x l / n) (setq n -1)(mapcar '(lambda (y) (if (eq i (setq n (1+ n))) x y )) l )) ;--- Tokkie ------------------------------------------------------Tokkie ------------------------------------------------------- Tokkie --- (c:Delete_Dilan) gr. Rlx ps.pps. edited code to include subfuction limitstring, fixitoa & void , part of my lib with little subfunctions so I forgot it the first time , just noticed it after I posted Edited January 9, 2018 by rlx Quote
ronjonp Posted January 9, 2018 Posted January 9, 2018 Try this: (defun c:foo (/ tmp) ;; Deletes "*.txt" files in temp dir! (foreach x (vl-directory-files (setq tmp (getenv "temp")) "*.txt") (vl-file-delete (strcat tmp "\\" x)) (print (strcat "DELETING >> " tmp "\\" x)) ) (princ) )(vl-load-com) Quote
dilan Posted January 9, 2018 Author Posted January 9, 2018 Try this: (defun c:foo (/ tmp) ;; Deletes "*.txt" files in temp dir! (foreach x (vl-directory-files (setq tmp (getenv "temp")) "*.txt") (vl-file-delete (strcat tmp "\\" x)) (print (strcat "DELETING >> " tmp "\\" x)) ) (princ) )(vl-load-com) Thank you.This is what you need. How can I do not to delete all the files .txt in the "Temp" folder? For example I need to delete the file 123.txt and 321.txt... Quote
Grrr Posted January 9, 2018 Posted January 9, 2018 Rlx, theres a tiny issue in the GetFolder subfunction you used - shell application object won't be released if the user specifies the folder. On the other hand I think (think?,more like studied from the pros) that those "external acad objects" must be released at all cost (which would mean error-trapping/wrapping). So heres a more reliable approach that you can use: ; msg - [sTR] - optional prompt message ; defpath - [sTR] - optional default path ; newfolderopt [T/nil] - T = display option to create new folder, else don't ; Examples: (GetFolder nil nil nil) ; (GetFolder "Hello world" "D:\\GAMES" T) (defun GetFolder ( msg defpath newfolderopt / shell folder parentfolder path ) (vl-catch-all-apply (function (lambda nil (setq shell (vlax-get-or-create-object "Shell.Application")) (setq folder (vlax-invoke-method shell 'BrowseForFolder 0 (cond (msg)("")) (if newfolderopt 0 512) (cond (defpath) ((strcat (getenv "userprofile") "\\Desktop\\"))))) (setq parentfolder (vlax-get-property folder 'ParentFolder)) (setq path (vlax-get-property (vlax-invoke-method parentfolder 'Parsename (vlax-get-property folder 'Title)) 'Path)) ) ) ) (foreach x (reverse (list shell folder parentfolder path)) (vl-catch-all-apply 'vlax-release-object (list x))) path ); defun GetFolder Quote
Grrr Posted January 9, 2018 Posted January 9, 2018 http://lee-mac.com/directorydialog.html Well thats the perfect approach, I just wanted to use my gray matter a bit. Quote
rlx Posted January 10, 2018 Posted January 10, 2018 Rlx, theres a tiny issue in the GetFolder subfunction you used - shell application object won't be released if the user specifies the folder.On the other hand I think (think?,more like studied from the pros) that those "external acad objects" must be released at all cost (which would mean error-trapping/wrapping). So heres a more reliable approach that you can use: ; msg - [sTR] - optional prompt message ; defpath - [sTR] - optional default path ; newfolderopt [T/nil] - T = display option to create new folder, else don't ; Examples: (GetFolder nil nil nil) ; (GetFolder "Hello world" "D:\\GAMES" T) (defun GetFolder ( msg defpath newfolderopt / shell folder parentfolder path ) (vl-catch-all-apply (function (lambda nil (setq shell (vlax-get-or-create-object "Shell.Application")) (setq folder (vlax-invoke-method shell 'BrowseForFolder 0 (cond (msg)("")) (if newfolderopt 0 512) (cond (defpath) ((strcat (getenv "userprofile") "\\Desktop\\"))))) (setq parentfolder (vlax-get-property folder 'ParentFolder)) (setq path (vlax-get-property (vlax-invoke-method parentfolder 'Parsename (vlax-get-property folder 'Title)) 'Path)) ) ) ) (foreach x (reverse (list shell folder parentfolder path)) (vl-catch-all-apply 'vlax-release-object (list x))) path ); defun GetFolder Just quickly cut some code from some of my appies so it may not have been the best ones. On the other hand , it took me about two minutes... but you're right have to clean up or out some of my old stuf. Thanx for the update and the advice , allways appreciated and never too old to learn gr. Rlx Quote
Grrr Posted January 10, 2018 Posted January 10, 2018 Thanx for the update and the advice , always appreciated and never too old to learn No worries, always happy to help out back. Quote
ronjonp Posted January 10, 2018 Posted January 10, 2018 Thank you.This is what you need. How can I do not to delete all the files .txt in the "Temp" folder? For example I need to delete the file 123.txt and 321.txt... You only need to delete 2 files? Or do these files always consist of 3 numbers in the name? Quote
dilan Posted January 10, 2018 Author Posted January 10, 2018 You only need to delete 2 files? Or do these files always consist of 3 numbers in the name? Not always. Changed plans. In the "Temp" folder I have a folder "Stpr". I need to delete all files .txt in the folder "Stpr". The names of the deleted files can be different, but the file extension is always one - is .txt Quote
rlx Posted January 11, 2018 Posted January 11, 2018 Not always. Changed plans. In the "Temp" folder I have a folder "Stpr". I need to delete all files .txt in the folder "Stpr". The names of the deleted files can be different, but the file extension is always one - is .txt Good luck with that one Ronjonp Quote
ronjonp Posted January 11, 2018 Posted January 11, 2018 Not always. Changed plans. In the "Temp" folder I have a folder "Stpr". I need to delete all files .txt in the folder "Stpr". The names of the deleted files can be different, but the file extension is always one - is .txt Try this: (defun c:foo (/ tmp) ;; Deletes "*.txt" files in temp\stpr dir! (foreach x (vl-directory-files (setq tmp (strcat (getenv "temp") "\\STPR\\")) "*.txt") (vl-file-delete (strcat tmp x)) (print (strcat "DELETING >> " tmp "\\" x)) ) (princ) ) (vl-load-com) Quote
ronjonp Posted January 11, 2018 Posted January 11, 2018 Good luck with that one Ronjonp Thankfully it's an easy change Quote
Lee Mac Posted January 11, 2018 Posted January 11, 2018 One-liner with a batch file... del %temp%\STPR\*.txt Quote
dilan Posted January 11, 2018 Author Posted January 11, 2018 Thanks ronjonp. That's what I need Quote
ronjonp Posted January 12, 2018 Posted January 12, 2018 Thanks ronjonp. That's what I need Glad to help Quote
