Good day everyone...
Got a simple problem... We have a attribute block... Used in finishings... May i ask if theres a lisp that make a code and automatically fills in? Like field tabs... What i mean is.. in a finishing code block like where u put stone(st) wood(wd) ceremic tile (ct) etc. And then code.. what i want to know is that, if u put the code st, the word stone will appear on the bottom of the block ...
Thanks in advance.
the first part is simple (ok, ok, so is the rest):
(defun c:tst ( / my-block input attribute-name-to-update )
 (setq attribute-name-to-update "material")
 (princ "\nSelect your block : ")
 (setq my-block (car (entsel)))
 (setq input (strcase (getstring "\nEnter material st (stone) , wd (wood) , ct (ceramic) : ")))
 (cond ((equal input "ST")(setq input "Stone"))
       ((equal input "WD")(setq input "Wood"))
       ((equal input "CT")(setq input "Ceramic"))
       (t (princ "\nInvalid input")(setq input nil))
 (if (and my-block input) (update_your_block myblock attribute-name-to-update input))
(defun update_your_block myblock (blk att val)
 (princ "update_your_block function under construction")
You might also look into the initget / getkword functions (learning vs shopping ;-) )
Bottom line is : no example / no code = no (full) solution (no code, no load)
:mrgreen:
gr. Rlx
Heres another way to prompt, and call it as a command:
(defun C:test ( / g tmp )
 (princ "\n[s]tone | [C]eramic | [W]ood")
 (and
   (= 2 (car (setq g (grread))))
   (setq tmp (vl-some '(lambda (x) (last (member (cadr g) x))) '((83 115 "Stone") (67 99 "Ceramic") (87 119 "Wood"))))
   (vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object)) (strcat tmp "\n"))
); defun
(vl-load-com) (princ)
Thanks guys... Ill try this codes..and yes, my bad. Ill post next time :).
Like the others you can have a pop list of items rather than type at keyboard. DCL was around in 2008. This would be a library code so you could use it multiple times in a lisp so could have materials, edges, finish etc all with seperate list of items also this means have to pick from list not make a mistake in typing. This example uses one of Lee-mac's great routines.
(if (not LM:listbox)(load "ListBoxV1-2.lsp")) ; loads the lisp if not already loaded
(setq lst (list "Stone" "Ceramic" "Plastic"))
(setq ans (nth 0 (LM:listbox "Pick material" lst 1))) ; calls the list box
(alert (strcat "you have picked " ans)) ; shows what you have picked
(setq lst (list "Champher" "Square" "Round")) ; 2nd list
(setq ans (nth 0 (LM:listbox "Edge Style" lst 1)))
(alert (strcat "you have picked" ans))
ListBoxV1-2.lsp
Edited by BIGAL
attachment.php?attachmentid=63146&cid=1&stc=1..here guys..as per my query... The ST finish code and the STONE as specified final finish... What would i like to happen is that when ST is typed in, STONE will aotumatically filled in... Because my problem is that both attribute is must be edited..😐😐😐
Apologies for the dual post... Network probkems...
..and thanks bigal for the response...
Did you try the code ? Just interested.
One method
(cond
((if ans "Stone")(setq 2ndans "ST"))
((if ans "Ceramic")(setq 2ndans "Ce"))
((if ans "Plastic")(setq 2ndans "Pl"))
Ok now a bit smarter when you pick from the list you can get the item number as well so Stone would be returning 0, using (nth X lst) with x as 0, a list starts at 0 so Plastic is 2.
Your list is now something like this for two answers
(setq lst1 (list "Stone" "ST" "Ceramic" "CE" "Plastic" "PL"))
and you pass in this example nth 0, 2 & 4 to the list box. length lst / 2 is how many.
So your block could have 2 attributes one hidden ST & Stone.
I just need a bit of time, some one else may jump in.
(setq ans (nth 0 (LM:listbox "Pick material" lst 2))) this returns the item number starts at zero so can use nth.
I tried...nothing happened
Maybe i cant understand where to insert these codes..
I tried...nothing happened😥😥😥
An example code note needs a block replace Myblock in code with your block name.
(defun c:ins2atts ( / lst1 lst2 att1 att2 ans x )
(setq lst1 (list "Stone" "ST" "Ceramic" "CE" "Plastic" "PL")) ; a dual list 2 items per entry
(setq x 0) ; counter
(setq lst '() ) ; create blank list
(repeat (/ (length lst1) 2) ; how many items to be displayed in dcl list
(setq lst (cons (nth x lst1) lst)) ; make list pick every second item in lst1
(setq x (+ x 2)) ; get next item
(setq lst (reverse lst)) ; reverse list
(setq ans (nth 0 (LM:listbox "Pick material" lst 2))) ; calls the list box and return item note option 2 is item
(setq att1 (nth (* ans 2) lst1)) ; attribute 1 needs * 2 for correct itme number not1 1st is zero 2*0 =0 so ok
(setq att2 (nth (+ (* ans 2) 1) lst1)) ; attribute 2
;(princ (strcat "\nAttribute1=  " att1 " Attribute2=  " att2))
; needs a block with 2 attributes
(command "-insert" "Myblock" (getpoint) 1 1 0 att1 att2)
(c:ins2atts)
