N3cr0Rav3 Posted January 29, 2018 Posted January 29, 2018 Hi all, could someone help me with that lisp or send to me something other, i use a changeblock.lisp, program works excellent, but i need to change block with their base point, that can be possible? Thanks. (defun c:CHANGEBLOCK(/ ACTDOC COPOBJ ERRCOUNT EXTLST EXTSET FROMCEN LAYCOL MAXPT CURLAY MINPT OBJLAY OKCOUNT OLAYST SCLAY TOCEN TOOBJ VLAOBJ *ERROR*) (vl-load-com) (defun *ERROR*(msg) (if olaySt (vla-put-Lock objLay olaySt) ); end if (vla-EndUndoMark actDoc) (princ) ); end of *ERROR* (defun GetBoundingCenter(vlaObj / blPt trPt cnPt) (vla-GetBoundingBox vlaObj 'minPt 'maxPt) (setq blPt(vlax-safearray->list minPt) trPt(vlax-safearray->list maxPt) cnPt(vlax-3D-point (list (+(car blPt)(/(-(car trPt)(car blPt))2)) (+(cadr blPt)(/(-(cadr trPt)(cadr blPt))2)) 0.0 ); end list ); end vlax-3D-point ); end setq ); end of GetBoundingCenter (if(not(setq extSet(ssget "_I"))) (progn (princ "\nSelect objects, need to replace ") (setq extSet(ssget)) ); end progn ); end if (if(not extSet) (princ "\nDistination objects isn't selected!") ); end if (if (and extSet (setq toObj(entsel "\nSelect original object ")) ); and and (progn (setq actDoc (vla-get-ActiveDocument (vlax-get-Acad-object)) layCol (vla-get-Layers actDoc) extLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex extSet)))) vlaObj(vlax-ename->vla-object(car toObj)) objLay(vla-Item layCol (vla-get-Layer vlaObj)) olaySt(vla-get-Lock objLay) fromCen(GetBoundingCenter vlaObj) errCount 0 okCount 0 ); end setq (vla-StartUndoMark actDoc) (foreach obj extLst (setq toCen(GetBoundingCenter obj) scLay(vla-Item layCol (vla-get-Layer obj)) );end setq (if(/= :vlax-true(vla-get-Lock scLay)) (progn (setq curLay(vla-get-Layer obj)) (vla-put-Lock objLay :vlax-false) (setq copObj(vla-copy vlaObj)) (vla-Move copObj fromCen toCen) (vla-put-Layer copObj curLay) (vla-put-Lock objLay olaySt) (vla-Delete obj) (setq okCount(1+ okCount)) ); end progn (setq errCount(1+ errCount)) ); end if ); end foreach (princ (strcat "\n" (itoa okCount) " were changed. " (if(/= 0 errCount) (strcat (itoa errCount) " were on locked layer! ") "" ); end if ); end strcat ); end princ (vla-EndUndoMark actDoc) ); end progn (princ "\nSource object isn't selected! ") ); end if (princ) ); end of c:CHANGEBLOCK Quote
Cad64 Posted January 29, 2018 Posted January 29, 2018 I have moved your question to the Autolisp section. Please post all your Lisp related questions here: http://www.cadtutor.net/forum/forumdisplay.php?21-AutoLISP-Visual-LISP-amp-DCL Quote
