Hi, today is my first day in this group.
I would like to thank the admin of this group for accepting my registration.
I join here to learn things, techniques, etc. and sometimes I encountered problems that I can't find solution by browsing on the internet. I'm sure you can help & teach me.
First thing I need your help is about flipping/mirroring the text content. I usually use this in wiring connection. The format is SOURCE/DESTINATION. So, for example, my wire label on one end is TB1.1/TB9.8. I need to label the other end with T9.8/TB1.1. As you can see, it mirrors or flips the value after the / symbol.
I'm using Lee Mac's CopySwapTextV1-7.lsp that copy or swap the texts but I don't know how to modify it so I can use it for my purpose.
I really appreciate your help.
Thanks
Welcome to this forum!
Im sure you can learn alot around here!
About your question, here is a very simple code:
I dont have time for a full code, but this may get someone started.
(setq test "Hello/Goodbye")
(setq result (strcat (substr test (+ 2 (vl-string-position (ascii "/") test))) "/" (substr test 1 (vl-string-position (ascii "/") test))))
"Goodbye/Hello"
Where the format is flipped.
Hi,
(defun C:test ( / f )
 (setq f
   '( ( c s / L cL )
     (cond
       ( (not (eq 'STR (type s))) nil)
         (if (member c (setq cL (vl-string->list s)))
           (apply 'strcat
             (apply 'append
               (mapcar
                 ''( (x / tmp)
                   (cond
                     ( (not x) (if L (list (vl-list->string L))) )
                     ( (= c x) (setq tmp L) (setq L nil) (list (vl-list->string (append tmp (list c)))) )
                     ( (setq L (cons x L)) nil )
                 (reverse (cons nil cL))
           s
 (princ "\nSelect texts to inverse: ")
 (foreach x
   ('((/ SS) (if (setq SS (ssget "_:L-I" '((0 . "TEXT")))) (vl-remove-if-not ''((x) (eq 'ENAME (type x))) (apply 'append (ssnamex SS))))))
   ('(( enx / g ) (setq g (assoc 1 enx)) (entmod (subst (cons 1 (f 47 (cdr g))) g enx))) (entget x))
thank you very much Aftertouch & Grrr... it works perfectly.
I replace "TEXT" with "MTEXT" so it will work with MTEXT too but it doesn't work with TEXT.
How to make it work for both TEXT and MTEXT?
thanks a lot...
"MTEXT,TEXT" .. You might run into issues with mtext formatting though.
thanks ronjonp... it helps a lot...
  • 6 years later...
For some reason, the generous code submission has not effect on the TEXT or MTEXT in a file with the MIRRTEXT setting both as 1 or 0 (zero).
I renamed Test to Fliptxt.lsp that appears to be run successfully.
