Grrr Posted February 2, 2018 Posted February 2, 2018 thanx Grrr. In the end (or should I say begin) the problem was the difference between vla-get-block or vla-get-blocks... one stupid letter... Doh, even I didn't saw it.. maybe next time before implementing the mapping routine into odbx, to test it first on the active dwg (for easier error-tracing). Yeah , my void only goes so many levels deep in an empty string that was because I wrote it before vlisp existed and before vl-string->list / -trim etc existed. And still it has served me well all the these years , pure nostalgia Ah, I see... altho I liked that subfoo, so I use it /a rewritten version/ in some of my DCL routines (to check for a valid edit_box input). Still solvable without vl-* : ; _$ (mapcar 'valid-p (list nil "" " " " " 123 "str" " ")) >> (nil nil nil nil 123 T nil) (defun valid-p ( s / c ) (cond ( (not (eq 'STR (type s))) s) ( (= s "") nil) ( (/= (setq c (substr s 1 1)) " ") t) ( (valid-p (substr s 2)) ) ) ); defun valid-p Quote
rlx Posted February 2, 2018 Posted February 2, 2018 Ah, I see... altho I liked that subfoo, so I use it /a rewritten version/ in some of my DCL routines (to check for a valid edit_box input). I realy like my 'tiny-lisp' functions , one-liners etc. but... only if they're stable else my code must read like a good book so I can understand what I meant a year later. I also like to put as much information on one line in my vlisp editor so I use 140 character lines in my code. It's a disaster when printing but I rarely print anyway and that way I can have allmost double the code in my window then when I would limit my lines to lets say 80 characters. And if anyone has a problem with that , just use format code in the vlisp editor. Only downside of my 'tiny-lisp'functions is that now and again I forget to include them when I post a code on a thread because they are spread out over all my lisp routines so if one routine hasn't got them I will always have another function that loads it. Well... it has been a long day so.... Quote
wimal Posted April 6, 2018 Posted April 6, 2018 This is a great code. Can you add one more option to change width factor of texts to 1. Quote
rlx Posted April 6, 2018 Posted April 6, 2018 This is a great code. Can you add one more option to change width factor of texts to 1. not tested (no time) but replace the following section : (defun change_text_style ( $dwg / odbxdoc acstyles style-obj fnt layout obj o-name bn bn-list ent) (if (and (setq odbxdoc (odbx_open $dwg)) (setq acstyles (vla-get-textstyles odbxdoc)) (setq style-obj (vla-add acstyles "Company_Name")) (setq fnt (findfile "C:\\Windows\\Fonts\\arialn.ttf"))) (progn (vla-put-fontfile style-obj fnt) (vlax-for layout (vla-get-layouts odbxdoc) (vlax-for obj (vla-get-block layout) (cond ; remove "AcDbText" "AcDbMText" to NOT update (m)text's ((member (vla-get-objectname obj) '("AcDbText" "AcDbMText" "AcDbAttributeDefinition")) (vla-put-StyleName obj "Company_Name")) ((= (vla-get-objectname obj) "AcDbBlockReference") (mapcar '(lambda(x) (vla-put-StyleName x "Company_Name") [color=red](vla-put-ScaleFactor x <put your width here>)[/color] ) (get-block-ent obj))) ) ) ) (vl-catch-all-error-p (vl-catch-all-apply 'vla-saveas (list odbxdoc $dwg))) ) ) ) have to start with my new project now , so I'll check later... gr. Rlx Quote
