Hey guys,
I'm trying to rotate an object by using 3 points and I'm wondering could you solve this problem -
; Rotate Reference Test
(defun C:test ( / o bp sp dp )
 (and
   (setq o (car (entsel "\nSelect object to rotate: ")))
   (setq o (vlax-ename->vla-object o))
   (setq bp (getpoint "\nSpecify base point for rotation: "))
   (setq sp (getpoint "\nSpecify source point: " bp))
   (not (grdraw bp sp 2 1))
   (setq dp (getpoint "\nSpecify dest point: " bp))
   ; (vlax-invoke o 'Rotate ..?)
 (and
   (vla-Rotate o (vlax-3D-point bp) (- (angle bp dp) (angle bp sp)))
Thanks Lee!
I was trying to simulate align, by having 4 points which define 2 segments and an object to be moved and rotated.
Now it works! :)
You're welcome!
This option is already available as part of the standard ROTATE command however...
Command: rotate
Current positive angle in UCS:  ANGDIR=counterclockwise  ANGBASE=0
Select objects: 1 found
Specify base point:
Specify rotation angle or [Copy/[color=red]Reference[/color]] <0>:
Yes, I know - I'm just trying to switch some command calls to activex (revising old routines). ;)
Just a hint: The base point for the Rotate method is expressed in the WCS.
