mousho Posted February 2, 2018 Posted February 2, 2018 Dear friends lets say that i want to draw somthing and i want to read the information from csv file. what i'm looking for is a lisp that read from csv file and store the cell content at A1/A2/A3... and when there is empty cell in the row he start to read the second col and store them as B1/B2/B3.... i search all the web with no succes plz help PAD.csv Quote
BIGAL Posted February 3, 2018 Posted February 3, 2018 Dont understand when you open the csv in excel it makes a pattern, to do with pads. You need to post a dwg or image about what it is your trying to do. Quote
mousho Posted February 3, 2018 Author Posted February 3, 2018 HI BIGAL i'm attaching DWG and part of my code what i want is set the parameter W1/L1/H1.... from the excel and not from autocad and after the routine is finish he will start to read from the second col of excel and so on. PAD.dwg PAD 3 STEPS - Copy (6).LSP Quote
BIGAL Posted February 3, 2018 Posted February 3, 2018 (edited) ziele is on the money it would be much easier to just use the csv than read from excel, yes you can do read an excel cell value I uses GETEXCEL.lsp Looking at it further you can build a big list combining each line of the csv file (("PAD1" "PAD2" "PAD3" "PAD4") ("WIDTH1" "400" "350" "" "") ("LENGTH1" "500" "460" "" "") ("HEIGHT1" "100" "80" "" "") ("WIDTH2" "300" "300" "" "") ("LENGTH2" "400" "350" "" "") ("HEIGHT2" "80" "70" "" "") ("WIDTH3" "200" "250" "" "") ("LENGTH3" "300" "300" "" "") ("HEIGHT3" "60" "60" "" "") ("WIDTH_COL" "40" "40" "" "") ("LENGTH_COL" "80" "80" "" "")) Using the nth function in a double repeat loop you can pull out the correct values for this part of your code W1 (getreal "\nEnter Width Of Pad (cm) :") L1 (getreal "\nEnter Length Of Pad (cm) :") H1 (getreal "\nEnter Hight Of Pad (cm) :") W2 (getreal "\nEnter Width2 Of Pad (cm) :") L2 (getreal "\nEnter Length2 Of Pad (cm) :") H2 (getreal "\nEnter Hight2 Of Pad (cm) :") W3 (getreal "\nEnter Width3 Of Pad (cm) :") L3 (getreal "\nEnter Length3 Of Pad (cm) :") H3 (getreal "\nEnter Hight3 Of Pad (cm) :") W4 (getreal "\nEnter Width Of Col (cm) :") L4 (getreal "\nEnter Length Of Col (cm) :") GetExcel.lsp Edited February 4, 2018 by BIGAL Quote
BIGAL Posted February 5, 2018 Posted February 5, 2018 Something like this (setq x 1) (set1 y 1) (while (/= (setq W1 (nth x (nth y lst))) nil) (setq L1 (nth x (nth (setq y (+ y 1)) lst))) (setq H1 (nth x (nth (setq y (+ y 1)) lst))) ...... Draw now (setq x (+ x 1)) (setq y 1) ) Quote
