(getstring (strcat "<" "Test" ">"))
Works like in the picture.
Is it possible to do not print the default value?
Just like the picture below.
Your looking for this?
(setq thestring (getstring "\nEnter string <TEST>: "))
(if (null thestring)(setq thestring "TEST"))
When there is no imput, the value is set to "TEST".
this part:
is just cosmetic, and could also be:
(getstring "\nEnter string: ")
I have a variable string:
(setq a "zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz")
I want to modify it using the function getstring
(getstring (strcat "<" a ">"))
That is now:
I want to have it without a prefix.
Is it possible?
@Kowal:
If you don't want this prompt why are you providing it?
If I'm understanding you correctly, you're just missing the brackets: (getstring (strcat "[]"))
Nice Ron, this is new for me!
Perhaps to make an useful prompt from this would be:
(cond ((= (setq v (getstring (strcat "[<" a ">]"))) "") a)(v))
Definitely :)
I use something like this a lot for getkword:
(or *default* (setq *default* "Width"))
(initget (setq options "Arc Length Width"))
(setq *default*	(cond ((getkword (strcat "\nPick an option: ["
				 (vl-string-translate " " "/" options)
				 *default*
	      (*default*)
Thank you ronjonp. I was looking for such a solution.
Ronjonp are we missing a defun ? Just got the normal input on command line.
My $0.05 with multiple key words can use a dcl list box method and pick only one. Need a library routine routine for the dcl but basicly 3 lines of code. Thanks to lee for listbox.
(if (not LM:listbox)(load "ListBoxV1-2.lsp")) ; loads the lisp if not already loaded
(setq lst (list "Stone" "Ceramic" "Plastic"))
(setq ans (nth 0 (LM:listbox "Pick material" lst 1))) ; calls the list box and return item
Not missing a defun just a simple example. You'll need to set dynmode to 1 to get the result at the cursor.
Thanks thought it would be a switch somewhere as you know there are so many. Need Dynprompt = 1 also. I work with the dynamics turned off a personal preference.
Ronjonp I like the idea so made it a library function, will probably use in future as I am moving my code away from command line input to a more in your face approach.
; get keyword on screen input by Ronjonp Jan 2018
;http://www.cadtutor.net/forum/showthread.php?102708-Getstring-a-default-value-without-print.
; modified by BIGAL Jan 2018 as a library function
(defun keyword (*default* options /  )
(setq olddynmode (getvar "dynmode"))
(setq olddynprompt (getvar "dynprompt"))
(setvar "dynmode" 1)
(setvar "dynprompt" 1)
(initget options )
	      *default*
	      (*default*)
(setvar "dynmode" olddynmode)
(setvar "dynprompt" olddynprompt)
; example
(keyword "Width" "Length Height Width")
Edited by BIGAL
Glad you could use it :). I generally draft with the dynmode set to 0 as well for performance. IMO .. I'd put an error function in that if you're changing variables within the function.
ronjonp good idea I have been meaning to write a bit of a reset lots error function as a library function, often need filedia reset.
Maybe something like this so you don't have a common global which might cause problems.
(defun keyword (key options default / *error* def vars)
 (defun *error* (msg)
   (mapcar '(lambda (x) (setvar (car x) (cdr x))) vars)
   (if	(not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
 (or (setq def (getenv key)) (setq def default))
 (setq vars (mapcar '(lambda (x) (cons x (getvar x))) (list 'dynmode 'dynprompt)))
 (mapcar '(lambda (a b) (setvar (car a) b)) vars '(1 1))
 (initget options)
 (setq	def
 (cond ((getkword
	  (strcat "\nPick an option: [" (vl-string-translate " " "/" options) "] <" def ">:")
       (def)
 (setenv key def)
(keyword "MyProgram" "Length Height Width Depth" "Height")
