Bogbadbob658 Posted February 5, 2018 Posted February 5, 2018 I have block (I didn't create it) which gives the xy co-ords of the insertion point but the precision is only to 2 decimal places and I need it to 3. How do I change it? I need it in a step by step answer as I don't really understand the attribute thing. Thanks in advance. Drawing3.dwg Quote
iconeo Posted February 5, 2018 Posted February 5, 2018 Go into attribute editor. Double click on the grey field. In the Field editor on the right hand side you will see the precision for the units. Quote
BIGAL Posted February 6, 2018 Posted February 6, 2018 A little bit more at the start Command: EATTEDIT Select a block: Quote
Bogbadbob658 Posted February 6, 2018 Author Posted February 6, 2018 Thank you. I wasted hours yesterday trying to work this out. Quote
