so i have drawings that have a lot of different text styles within it, (this was a work provided thing.) and i want to be able to change all the text to the same.
without having to go and select similar or click one by one. here is something that i found that seems to work pretty good for me but i am getting a message at the end of the routine asking me questions, i am not seeing this within the text. or i am just blind.
(defun C:CTS (/ entities len count ent ent_data ent_name new_style_name)
(command "STYLE" "Standard" "Romans" "" "" "" "" "")
(setq entities (ssget "X" '((0 . "TEXT,MTEXT")))
     len      (sslength entities)
     count 0
);setq
(while (< count len)
      (setq ent      (ssname entities count)
            ent_data (entget ent)
            ent_name (cdr (assoc 7 ent_data))
      );setq
(setq new_style_name (cons 7 "Standard"))
(setq ent_data (subst new_style_name (assoc 7 ent_data) ent_data))
(entmod ent_data)
Y
(setq count (+ count 1))
);while
);defun
here is what is showing up in the command line
Command: changestyle
STYLE Enter name of text style or [?] <Standard>: Standard
Existing style. Full font name = Arial
Specify font name or font filename (for SHX) <Arial>: Romans Specify height of text or [Annotative] <0'-4">: Specify width factor <1.000>:
and the questions that are being asked:
specify obliging angle <0.00>: display text backwards? [yes/no] <no>:
display text upside-down? [yes/no] <no>: vertical? [yes/no] <no>: vertical? [yes/no] <no>:
is there something that i am missing here?
There are many custom lisp routines that will change a text style. Try looking for another one. Maybe you'll have better results.
i have been looking and most of the ones that i am seeing are ones that you have to select what you want to change. and i want to have this be a one and done.
i am still green with writing lisp routines that i am not sure where to isolate that to add and/or replace that to another lisp. that is why i am asking for a little help to identify that
