Pickledcleric
Dxf default to "save objects:
Pickledcleric
Hi Guys, I'm using autocad 2015. I save a lot of dxf files to convert to G-Code. When saving a dxf, is there a way to automatically turn on the "select objects" option in the "save as dialogue box"
I must turn it on 30 times a day
Thanks
the cleric
Share this post
Link to post
SLW210
You could make a Script or maybe a Button Macro, if you want to do those, set FILEDIA=0, then you will get a commandline version of SAVEAS (same as DXFOUT), just look at the commanline for the options you want.
You might look at using a LISP.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
