wimal Posted February 14, 2018 Posted February 14, 2018 Border lines of texts not smooth on drg 2. that texts copy paste to a new drawing 1. now the borders are ok. What are the settings I have to change in drg 2 to get smooth borders. Used font type is Arial Narrow. Width factor is 1. No Z values Text alignment Z = 0 Quote
Dana W Posted February 15, 2018 Posted February 15, 2018 It just has not been refreshed. Have you used the command REGEN to regenerate the screen display? Quote
wimal Posted February 16, 2018 Author Posted February 16, 2018 Can you post a .dwg? Yes I have attached it PP134-17-12 - Sarath-youth center @ matale - FOUNDATION-F1.dwg Quote
SLW210 Posted February 16, 2018 Posted February 16, 2018 See if the information in this post helps...Fat Fuzzy Text. Somehow your text is out of whack. When you use TXTEXP on them, they get large and move way off. Moving to a new drawing fixes it as you know. Do you know the original source for the drawing? Quote
wimal Posted February 17, 2018 Author Posted February 17, 2018 See if the information in this post helps...Fat Fuzzy Text. Somehow your text is out of whack. When you use TXTEXP on them, they get large and move way off. Moving to a new drawing fixes it as you know. Do you know the original source for the drawing? Thanks for you for spending your valuable time to help me Quote
