Ibanezboy21
block to stay centered while stretching
Ibanezboy21
Hi guys,
I'm trying to have the base point of this block centered so when i put this window in a room, i could change the size without readjust the window back to the center of the room?
i know i could have 2 stretch actions to stretch both sides but i want the full window opening size to be shown at the bottom while im stretching.
any ideas?
wintest.dwg
Share this post
Link to post
steven-g
Change the basepoint of the distance parameter in properties to the center and then add another stretch action at the left hand end (and move the insert point to the center of the block)
Share this post
Link to post
BIGAL
If your happy with a manufacturers standard sizes then you can have a pop up of std sizes as part of the dynamic block rather than drag or enter width. Post if you want an example.
Share this post
Link to post
Ibanezboy21
Hi Steven,
if i put the stretch midpoint will it show only half the distance or the full opening dimension which i am after?
Share this post
Link to post
Ibanezboy21
@ Bigal
interesting, can i please see an example?
Share this post
Link to post
BIGAL
This was not done by me but a good example. I do apologise I dont have original contributors name.
DYNAMIC BOLT.dwg
Share this post
Link to post
iconeo
Not sure about that dynamic bolt block because I don't believe it is setup to work with a midpoint stretch...
Anyways, please take a look at the posted block and you'll see that I used a parameter set with 2 stretches. I placed the midpoint at 0,0 for simplicity. Don't forget to change the parameter properties to stretch from midpoint.
Thanks.
wintest.dwg
Share this post
Link to post
steven-g
Hi Steven,
If you had bothered to try it you would see. I did try it so I know what it does.
Share this post
Link to post
Ibanezboy21
Thanks.
[ATTACH]63345[/ATTACH]
oh its that simple, thanks for posting an example.
Seems like I've been doing it the wrong way all along....
Share this post
Link to post
Ibanezboy21
Sorry Steven i did try it in the past but i think i was doing it incorrectly (using 1 grip for distance parameter instead of 2)
i've learnt to make blocks using youtube videos so im still learning everday
Share this post
Link to post
Ibanezboy21
hey guys,
so i've changed the stretch parameter and it works fine, except i have no idea why the insertion point is to the side of the block.
I've tested the block inside block editor and it works fine but once i exit it, the base point is to the side.
any idea whats wrong with it?
testwin.dwg
Share this post
Link to post
iconeo
hey guys,
Because that is where you placed your basepoint object.
Share this post
Link to post
Ibanezboy21
Hi Iconeo,
so how do i fix it? sorry for sounding dumb, i am very new to this
Share this post
Link to post
iconeo
Personally, I would add insert points (move grips or points) at the ends and midpoints of the windows and remove the basepoint object altogether.
Share this post
Link to post
