The Pan command doesn't work on my mouse. The button died. :ouch:
does anyone have a Pan lisp? the Pan version I am looking for is the Pan with the hand cursor. not -pan.
I made this but it is garbage. I would like the dufun = 11 for my hot key.
Pan
(defun c:11()
(command "Pan"))
Thank you for your time :)
Ummmm .. buying a new mouse seems like the most direct answer.:lol:
Or try (setvar 'mbuttonpan 1) .. maybe it's not the mouse.
Yeah I know but I am at work right now...
Did you try this?
I tried to modify my pan command to 11 months ago but I suck at writing lisp.
Yes it is set to one. My poor little mouse is dying. we had a good time together at work.
:) ... when you say you're trying to make '11' hotkey lisp are you referring to mapping to a function key?
Sorry I am not sure what you are asking. I do a lot of wire runs and fillet command so I use:
(defun c:5()
(command "LINE"))
(defun c:6()
(command "fillet"))
I would like pan set up as 11 if possible and add it to my lisp list.
How about RMB:
(defun pancakes:CB ( rtr args )
 (vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object)) "PAN")
(foreach rtr (cdar (vlr-reactors :VLR-Mouse-reactor)) (if (= "pancakes" (vlr-data rtr)) (vlr-remove rtr)) )
(vlr-Mouse-Reactor "pancakes" '((:VLR-BeginRightClick . pancakes:CB)))
(vl-load-com)(princ)
Edited by Grrr
Unknown command "PANCAKES". Press F1 for help.
CB Constainbar ?
Using Grrr's idea .. this should do what you want:
(defun c:11 nil (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "PAN "))
How about RMB:
(foreach rtr (cdar (vlr-reactors :VLR-Editor-reactor)) (if (= "pancakes" (vlr-data rtr)) (vlr-remove rtr)) )
Cool idea but breaks the right click menu :shock:
Thanks Ron, I know I know.. :lol:
Reminds me of Lee's reactor that retrieves the last command call (due my request) - I find it awesome!
Duh, corrected a mistake:
(cdar (vlr-reactors :VLR-[b]Mouse[/b]-reactor)
  • 5 months later...
