jim78b Posted March 1, 2018 Posted March 1, 2018 I have acad 2013 when i start the program i set tool palette and properties Windows open .I see when Close drawings. Dwg and run command recover ...after recover a dwg .I open dwg but acad Close tool palette and properties window why this ? Quote
CyberAngel Posted March 1, 2018 Posted March 1, 2018 This is why punctuation is important, kids. Sorry, I don't understand the problem. You may need to save your workspace. Quote
jim78b Posted March 1, 2018 Author Posted March 1, 2018 This is why punctuation is important, kids. Sorry, I don't understand the problem. You may need to save your workspace. Sorry i try to explain. If i have acad with no drawing open.and use recover .acad recover the dwg open it and i don t find my tool palette and properties window . While if i use recover command when a dwg file is open the tool palette and properties window are present is it normal ? Quote
iconeo Posted March 2, 2018 Posted March 2, 2018 That is odd, you don't have a acaddoc.lsp in the directory of the files you are trying to open do you? Quote
jim78b Posted March 2, 2018 Author Posted March 2, 2018 That is odd, you don't have a acaddoc.lsp in the directory of the files you are trying to open do you? I had never acaddoc.lsp. in any dir of my pc when i open my files . Quote
