I'm looking for a way to automate this process using AutoLISP:
Copy an existing PDF file from a network location to a different specified directory,save it under a new name, and then open it.
Any help with this is appreciated, and I thank you folks in advance for your time and knowledge. :)
Thanks Lee, I this works for me-
(defun c:test1 (/ )
(vl-file-copy "c:/pdf/something.pdf" "c:/workarea/somethingelse.pdf")
(vl-cmdf "start" "c:\\workarea\\somethingelse.pdf")
(princ))(princ)
-as long as there is no spacing in the directory or file names. You gave me this a while back to fix the spacing problem when opening a file, do you have something similar that allows spacing when using vl-file-copy?
(defun c:test2 (/ )
(lm:open "C:\\2018 Standards\\2018 PDF\\name with spaces.pdf")
(princ))(princ)
(defun lm:open ( target / rtn shl )
(vl-load-com)
(if (and (or (= 'int (type target)) (setq target (findfile target)))
(setq shl (vla-getinterfaceobject (vlax-get-acad-object) "shell.application")))
(setq rtn (vl-catch-all-apply 'vlax-invoke (list shl 'open target)))
(vlax-release-object shl)
(if (vl-catch-all-error-p rtn)
(prompt (vl-catch-all-error-message rtn)) t)))(princ))(princ)
(vl-file-copy (findfile "something.pdf") "c:\\directory with spaces\\somethingelse.pdf")
(princ))(princ)
