wimal Posted March 23, 2018 Share Posted March 23, 2018 Detach is active. But nothing happened when press it. Unload and reload is active. I need to bind the grid file to the drawing. But both files binding to drawing.? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 23, 2018 Share Posted March 23, 2018 Did you try -PURGE on the drawing? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted March 23, 2018 Share Posted March 23, 2018 When that happens to me, it's usually because the xrefs are nested. In other words, you have to open another xref and detach your xref in that drawing, save it, and go back to the original drawing. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 23, 2018 Share Posted March 23, 2018 It could be that the xref is inserted more than once in the drawing, like a title block for instance. If your title block is inserted on multiple layout tabs, you cannot Detach it until you manually delete all the other instances. Then you can Detach. Also, I always insert my xrefs with "Type" set to "Overlay". That way the nested xrefs, (if there are any), don't come through into my drawing. Quote Link to comment Share on other sites More sharing options...
wimal Posted March 24, 2018 Author Share Posted March 24, 2018 Many thanks for all of you. Quote Link to comment Share on other sites More sharing options...
