I thought this simple program would run, but it looks like I am asking it to do something where the code hangs up and I have to kill the process.
The pseudocode is:
  1. Select all of the drawing
  2. Copybase 0,0
  3. Do a "qnew" for a new drawing
  4. Paste clip 0,0 into new drawing
(defun c:test ( / s )
   (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "select all \r\r"))
   (if (setq s (ssget)) (command "_.copybase" "_non" '(0 0) s ""))
   (command "._qnew")
   (command "_.pasteclip" "_non" '(0 0))
(vl-load-com)
Which part is not correct?
Greg
Guess you want to paste selection in new template file and not able to use saveas... what's the use of the vla-sendcommand???
but to answer your question , I think that as soon as you start a new drawing your lisp routine stops because lisp runs in its own namespace. What you need is a script file...
gr. Rlx
Ok, so this one works better in that it will create a new drawing and does not hang up. But it does not paste the information and it wants to create two drawings.
   (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "qnew \r"))
(vl-load-com)
Greg
gr. Rlx
Hmmm. That makes sense now that you mention it. So a VBA routine would work?
Greg
you could also try to make a script file , for example 'change_template.scr' and save it where ever you want , in your support path but lets say c:/temp/
the script file could look like :
copybase
0,0
all
qnew
y
pastclip
0,0
you might not need the empty line on line 7 if the autocad template is pre-set.
Then all you would need is call the script :
script
c:/temp/change_template.scr
all is left then is to save the drawing with the name of your choise
oopsie had one 0,0 too many , updated the code above
Greg
yes VBA should work because VBA operates on autocad as an object where lisp only lives in the drawing session.
copybase
0,0
all
qnew
y
pastclip
0,0
script
Thanks rlx! I'll give that a try.
Greg
Thanks. For now, that is my new Plan B.
Greg
good catch Grrr , maybe little more complicated to use but also more fun :-)
WBLOCK?
but base UCS coordinates
Edited by hanhphuc
link expired
WBLOCK?but base UCS coordinates
that would be plan D? I'm losing count here :P hope OP has enough choises by now.
BTW theres another plan E (by investigating plan C) :
(defun test ( / cad acDoc acSS v i nDoc )
 (setq cad (vlax-get-acad-object))
 (setq acDoc (vla-get-ActiveDocument cad))
 (setq acSS (vla-get-ActiveSelectionSet acDoc))
 (vlax-invoke acSS 'Select acSelectionSetAll)
 (setq v (vlax-make-safearray vlax-vbObject (cons 0 (1- (setq i (vlax-get acSS 'Count))))))
 (vlax-for o acSS (vlax-safearray-put-element v (setq i (1- i)) o))
 (setq v (vlax-make-variant v))
 (setq nDoc (vla-Add (vla-get-Documents (vlax-get-acad-object))))
 (vla-CopyObjects acDoc v (vla-get-block (vla-Item (vla-get-Layouts nDoc) "Model")))
 (vlax-put-property cad 'ActiveDocument nDoc)
 (and acSS (vl-catch-all-apply 'vla-Delete acSS))
); defun
:lol:
:lol:
OP says : "how about plan F? let's get some beer" :beer:
:rofl:
:rofl:
thát's the best plan I've heard so far!
:beer: cheers guys! burp , oh , excuse me...
BTW theres another plan E (by investigating plan C) ::lol:
nice wblock Grrr :D
Ok, I don't know what Plan iteration this is, but this is where I am in the process of writing .scr file:
filedia 0
copybase
0,0
all
qnew
pasteclip 0,0 zoom all qsave
I want to save the path/name to a variable an save it to a subfolder (like "xyz"). Can that be done?
Greg
