Hello everybody.
Is it possible to implement this?
I load the program into the autocad, the program determines from which folder I load it, and this folder is added to the support file search paths.
There is some sort of implementation for Bricscad AFAIK. If you are using APPLOAD for loading or NETLOAD for dlls I doubt it is possible... If you copy+paste lsp file into CAD interface, then my thinking is that you could use LOGFILEON command prior, search for *.log file - look into (getvar 'LOGFILENAME), then do LOGFILEOFF and after you look into *.log, perhaps you could find path by using (setq fn (open "....log" "r")) and (while (setq li (read-line fn)) ... (setq path (substr li ...)) )
(vla-get-supportpath (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
You also need to add trusted location as you have 2017
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
(setq paths (vla-get-SupportPath *files*))
(setq pathsnew "newsupportpath;")
(setq newpath (strcat pathsnew paths))
(vla-put-SupportPath *files* newpath)
; trusted path is a setenv
(setq paths (strcat pathsnew (getenv "trustedpaths")))
(setenv "trustedpaths" paths)
The other way is to have a lisploader as a alternative to appload. Just find the file you want to load change the preferences then use a (load myprogram)
(setq fname "P:\autodesk\mylisps\Add-to-levels-multi.lsp")
; check if path exists if not add
(setq fname "Add-to-levels-multi.lsp") ; lisp file name to be loaded no path required
(load fname) ; loads lisp file and now runs new lisp file.
I got something like this:
;; (SL_AddSupportPath (appload-folder)) - function call ;;
(defun AddSupportPath (dir / tmp Cpath Path)
 (vl-load-com)
(setq Path (appload-folder))
(setq Cpath (getenv "ACAD")
       tmp   (strcat ";" dir ";")
(if (not (vl-string-search dir cpath))
   (setenv "ACAD" (strcat Cpath ";" dir))
 (defun appload-folder ()
   (vl-registry-read
     (strcat
"HKEY_CURRENT_USER\\"
(vlax-product-key)
"\\Profiles\\"
(getvar 'cprofile)
"\\Dialogs\\Appload"
     "MainDialog"
It seems everything works, the folder from which I load the program is added SupportPath.
Please look, maybe there needs to be something to fix? I mean, this code could not be done correctly.
Sorry, (AddSupportPath (appload-folder)) - function call
