Dear coders,
Just want to set simple property using LISP
but getting different errors,
i want to set this property after i added an new attdef into my dwg using vla-addattribute syntax
Any an idea how to set this?
I try to set this value
_$ ins1
(0.0 0.0 0.0)
; error: Automation Error. Not applicable
_$ (vlax-put-property att 'Alignment prop1)
nil
_$ (vlax-put-property att 'TextAlignmentPoint (vlax-3D-point ins1))
_$ (vlax-3D-point ins1)
_$ ins1
(0.0 0.0 0.0)
_$ (vlax-put-property att 'TextAlignmentPoint ins1)
; error: lisp value has no coercion to VARIANT with this type: (0.0 0.0 0.0)
Even getting the prop and resetting it fails
_$ (vlax-get-property att 'TextAlignmentPoint)
_$ (setq test (vlax-get-property att 'TextAlignmentPoint))
_$ (vlax-put-property att 'TextAlignmentPoint test)
maybe this helps :
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-ActiveX/files/GUID-27030E1C-6480-4A64-BE0A-E72C1FFF2023-htm.html
or
;;---------------=={ Match Text Properties }==----------------;;
;;  Prompts for a selection of Text, MText, Attribute, or     ;;
;;  Attribute Definition object to use as property source,    ;;
;;  then proceed to match those properties listed for similar ;;
;;  objects selected thereafter.                              ;;
;;  Author: Lee Mac, Copyright © 2010 - www.lee-mac.com       ;;
(defun c:MTP nil (c:MatchTextProps))
(defun c:MatchTextProps ( / *error* _StartUndo _EndUndo _GetTextInsertion _PutTextInsertion Props doc entity object ss )
 (vl-load-com)
 ;; © Lee Mac 2010
 (setq Props
    Alignment
    AttachmentPoint
    BackgroundFill
    Backward
    DrawingDirection
    Height
    Layer
    LineSpacingDistance
    LineSpacingFactor
    LineSpacingStyle
    Linetype
    LinetypeScale
    Lineweight
    ObliqueAngle
    Rotation
    ScaleFactor
    StyleName
   ; TextString
    Thickness
    UpsideDown
    Width
 (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (defun *error* ( msg )
   (if doc (_EndUndo doc)) (if mutt (setvar 'NOMUTT mutt))
       (princ (strcat "\n** Error: " msg " **")))
 (defun _StartUndo ( doc ) (_EndUndo doc)
   (vla-StartUndoMark doc)
 (defun _EndUndo ( doc )
   (if (= 8 (logand 8 (getvar 'UNDOCTL)))
     (vla-EndUndoMark doc)
 (defun _GetTextInsertion ( object )
   (vlax-get-property object
     (if
       (or
         (eq "AcDbMText" (vla-get-ObjectName object))
         (vl-position (vla-get-Alignment object)
           (list acAlignmentLeft acAlignmentFit acAlignmentAligned)
       'InsertionPoint
       'TextAlignmentPoint
 (defun _PutTextInsertion ( object point )
   (vlax-put-property object
     (if
       (or
       'InsertionPoint
       'TextAlignmentPoint
     point
 (if
   (and
     (setq entity
       (LM:Selectif
         (lambda ( x )
           (wcmatch (cdr (assoc 0 (entget x))) "TEXT,MTEXT,ATTRIB,ATTDEF")
         nentsel "\nSelect Source Object: "
       (setq mutt (getvar 'NOMUTT))
       (setvar 'NOMUTT 1)
       (princ (strcat "\nSelect Destination " (cdr (assoc 0 (entget entity))) " objects: "))
       (setq object (vlax-ename->vla-object entity)
         ss
          (ssget "_:L"
            (list
       (setvar 'NOMUTT mutt) ss
     (lambda ( i values / entity obj )
       (_StartUndo doc)
       (while (setq entity (ssname ss (setq i (1+ i))))
         (setq obj (vlax-ename->vla-object entity))
         (mapcar
           (function
             (lambda ( prop value )
               (if
                 (vl-catch-all-error-p
                   (vl-catch-all-apply
                     (function
                       (lambda nil
                         (if (and (vlax-property-available-p obj prop t) value)
                           (if (vl-position prop '(Alignment AttachmentPoint))
                               (lambda ( insertion )
                                 (vlax-put-property obj prop value)
                                 (_PutTextInsertion obj insertion)
                               (_GetTextInsertion obj)
                 (princ (strcat "\n** Error Applying Property: " Prop " **"))
           Props Values
       (_EndUndo doc)
     -1
     (mapcar
       (function
         (lambda ( prop )
           (if (vlax-property-available-p object prop)
             (vlax-get-property object prop)
       Props
;;---------------------=={ Select if }==----------------------;;
;;  Continuous selection prompts until the predicate function ;;
;;  foo is validated                                          ;;
;;  Arguments:                                                ;;
;;  foo - optional predicate function taking ename argument   ;;
;;  fun - selection function to invoke                        ;;
;;  str - prompt string                                       ;;
;;  Returns:  selected entity ename if successful, else nil   ;;
(defun LM:Selectif ( foo fun str / e )
 ;; © Lee Mac 2010
 (while
   (progn (setq e (car (fun str)))
     (cond
       ( (eq 'ENAME (type e))
         (if (and foo (not (foo e)))
           (princ "\n** Invalid Object Selected **")
 e
Edited by rlx
If the Alignment property of single-line text or single-line attributes is set to Left (equivalently DXF groups 72 & 73 both set to 0), then the position of the text or attribute is instead determined by the InsertionPoint property (or DXF group 10); if the justification is anything other than Left, then the position is determined by the TextAlignmentPoint property (or DXF group 11).
This behaviour is clearly described in the 'Remarks' section of the documentation for the TextAlignmentPoint property:
Remarks
Text: This property will be reset to 0, 0, 0 and will become read-only when the Alignment property is set to acAlignmentLeft. To position text whose justification is left, fit, or aligned, use the InsertionPoint property.
I found the issue
For some strange reason the attdef i have seems to be made out of MTEXT
It only has the justification options you see with MTEXT
I try to set a value that does not exist for the mtext justification
Just wonder how it is possible to end up with attdef that has same justification as mtext
