I need to extend a lot of line and keep track of them.
So i need to change color of my extended lines.
Is there any way or lisp that can extend and change lines color with 1 command ??
Thank You.
Are all the lines going to be extended the same distance?
Are all the extended lines going to be changed to the same color?
Is the color of the extended lines tied to a specific layer?
The only solution that occurs to me is to isolate the affected lines and the target to extend to. Change the lines to another layer. Extend them. Unisolate.
If you want to change the color of the segment from the original endpoints to the new endpoints, that's another story. You'll probably need to write code for that.
