Falconbob Posted April 8, 2018 Posted April 8, 2018 I have the .ctb to Plot A0 size. I set the lightweight to (Use Object Lightweight) to use the Layer lightweight. everything is going well. the problem is when I use the same .ctb to Plot A4 size. the layers lightweight output are different Quote
ReMark Posted April 9, 2018 Posted April 9, 2018 So you want lines that are depicted with a heavier lineweight in the A0 size plot to retain that same lineweight in the smaller A4 size plot despite the fact it is 1/4 the size? Quote
tzframpton Posted April 10, 2018 Posted April 10, 2018 I believe this is an issue with viewport scale. This depends on how you're printing/plotting. Quote
