Hi!
I tried this in AutoCAD 2018:
(defun c:CCA ()
 (setq R 10)
 (setq H 10)
 (setq N 1)
 (command "circle"  p1  R)
 (while
 (setq p1 (getpoint "Centre:"))
 (command "Text" "j" "M" p1 H 0 N "" )
 (setq N (+N 1 ))
but result:
bad argument type: 2D/3D point: nil
Can somebody help me? thanks a lot.
Edited by SLW210
Added Code Tags.
Hi,
The first variable p1 is equal to nil when you start up that routine so that's why it fails.
Just for your understanding;
(defun c:cca (/ r h n p1)
 (setq r 10
       h 10
       n 0
 (while (setq p1 (getpoint "Centre:"))
   (command "circle" "_non" p1 r)
   (command "Text" "j" "M" "_non" p1 h 0 (setq n (1+ n)))
; see tharwat :-)
sorry Tharwat , didn't see your response when I submitted...
