Mystogan Posted April 11, 2018 Posted April 11, 2018 Hi to all, Using overkill command is very great help in deleting some overlapping in the dwg. Is there a command or LISP that can delete any overlapped blocks(block with attribute)? Hoping someone can post his/her code for delete overlapped blocks TIA Quote
dlanorh Posted April 13, 2018 Posted April 13, 2018 Hi to all, Using overkill command is very great help in deleting some overlapping in the dwg. Is there a command or LISP that can delete any overlapped blocks(block with attribute)? Hoping someone can post his/her code for delete overlapped blocks TIA Overkill should delete any duplicate objects provided you have set it up correctly. If you are trying to use it in the block editor then it won't work prior to 2013 IIRC Quote
BIGAL Posted April 13, 2018 Posted April 13, 2018 Do you mean the same block twice at the same point ? Quote
rlx Posted April 14, 2018 Posted April 14, 2018 Do you mean the same block twice at the same point ? just a quick google : 1) http://www.theswamp.org/index.php?topic=50296.0 2) https://www.ellenfinkelstein.com/acadblog/remove-duplicate-and-overlapping-objects/ near the bottom of the web page (Ross, October 1, 2015 at 9:38 am) : overkill WILL remove duplicate blocks in 2015. the readout in the command line will not reflect that it remove them, but in actuality it does. 3) http://www.cadtutor.net/forum/showthread.php?46908-Remove-block-duplicates-with-different-attributes Quote
dlanorh Posted April 14, 2018 Posted April 14, 2018 It will remove duplicate blocks in 2012, and by duplicate i've assumed the same block with the same insertion point and same scaling. A problem i've noticed is that no one pays attention to the "tolerance setting" and "ignore object property" check boxes. With the tolerance setting, if any two blocks are inserted within 0.1mm of each other, one of them is usually a duplicate, yet people run the command with a tolerance of 0.0000001!! So adjust your tolerance to suit the drawing units and the type of work. Quote
Mystogan Posted April 17, 2018 Author Posted April 17, 2018 Thank you everyone for your reply, I guess using old version of autocad 2011 is not a good thing to do.. Even in LeeMac work on #3 of sir rlx is not working Quote
